17264 Discussions
sorting 4 numbers with controller and datapath
hi
i'm working on a machine that sorts 4 numbers with 4 bits.
i can't understand why it doesnt work.
i made it by ussing "bubble sort" technique
all files here include an image of the machine.
the machine works well with the second and the third numbers but it doesnt works with the first and the fourth.
compare2 - the comperator
contcomp- controller
top - the main.
thanks in advance
an easy way is to address four locations (out of 16) with the numbers serially and write value 1 there then read them back.
e.g. if address sequence (A,B,C,D] is 11, 15,0,1 then
addresses 0,1,11,15 will be set to 1, others 0
read back from 0 to 15
min will be first address with 1 and so on
