when i use the EP1C6, i can set the pins SSTL3 ,
but when the FPGA which is replaced by the ep3c5 , the the code is not changed ,then i find the pins have not the SSTL3 , so i have questions is that 1 : why the sstl-3 class2 is in ep1c6,and the ep3c5 have not it ? 2 :when i use the ep3c5 ,how i set the pin to instead of sstl-3 class2 ? 3: when i use the 3p3c5,and set one of bank SSTL-2, then the 1) (IO vref ) of the bank is seted 2.5v ? or 3.3V? or not set ? 2) vccio of the bank is seted 2.5v ? or 3.3V? or not set ? thank you very muchLink Copied
who can tell me ? thankyou
