17255 Discussions
std_logic to std_logic_vector in port map
I am newbie in VHDL design and reading literature did not help ...
I created entity to sync signal(s) to clk. I would like to have it generic and use it for both single signals (n=1) and vectors (n>1). The entity is declared as:
entity sync2 is generic ( n : positive := 2 -- width ); port ( -- inputs d : in std_logic_vector (n-1 downto 0); clk : in std_logic; -- clock reset : in std_logic; -- asynchronous reset -- outputs q : out std_logic_vector (n - 1 downto 0) ); end entity sync2;
It works perfectly for vectors but I do not know, how to connect std_logic signal to the input vector, which is in this case std_logic_vector(0 downto 0);
Or is it possible to overload the declaration so the d is std_logic?
signal sig1 : std_logic; signal sig2 : std_logic; ------------------------------------------------------------------------------- -- Instantiation of entity ------------------------------------------------------------------------------- sync : entity work.sync2 generic map ( n => 1 ) port map ( d => sig1, q => sig2, reset => reset, clk => clk );
If n is say 2 and you want just put a std logic signal into d you have to do something like
d => '0' & sig1,
which fills up the other spaces with zero.
If n = 3 it'll be
d => "00" & sig1,
notice the double quotation marks this time.
& is used for concatination in VHDL.
Cheers
Yes, but what if n = 1. How do I code it? In meantime i found i can use following syntax:
sync : entity work.sync2 generic map ( n => 2 ) port map ( d(0) => sig1, q(0) => sig2, reset => reset, clk => clk );
