17263 Discussions
std_logic_vector type does not match integer literal
Error (10517): VHDL type mismatch error at Transmit2.vhd(118): std_logic_vector type does not match integer literal
at
constant preamble : STD_LOGIC_VECTOR (31 DOWNTO 0) := 16#55#; -- 16 bits * 2 = 32
--- Quote Start ---
--- Quote End ---
That's true according to VHDL specification. Unless you apply a type conversion, std_logic_vector can be only assigned to a bit string literal of correct bit length, e.g.
constant preamble : STD_LOGIC_VECTOR (31 DOWNTO 0) := x"00000055";
success
For hex number
16## <- this wrong
x"" <- this correct
x"012345" is a hex string. It is not an integer.
i got it, so that i write for hex number, in the another post, i thought it as an integer
