stop inferred RAM
I hope someone can help, I am not too familiar with verilog and and trying to edit and SOPC component to stop it using M4K blocks and instead use registers.
Is there a way to stop Quartus inferring RAM nodes?
Below is the bit of code.
module raminfr (clk, we, a, dpra, di, dpo); parameter addr_width = 4; parameter data_width = 8; parameter depth = 16; input clk; input we; input a; input dpra; input di; output dpo; reg ram ; wire dpo; wire di; wire a; wire dpra; always @(posedge clk) begin if (we) ram <= di; end assign dpo = ram; endmodule Thanks in advance.
Richard
try Assignments => Settings => Analysis & Synthesis Settings => More Settings => Auto RAM Replacement to off.
though when i compiled this in Quartus it wouldn't infer a RAM due to the asynchronous read.
thanks, but is there a way to specify not to automatically use RAM for this bit of code. I am not sure if turning this feature off will effect other parts of my design (I am trying this now).
Richard
try looking at:
http://www.altera.com/literature/hb/qts/qts_qii51008.pdf
page 53
ramstyle = "logic" synthesis attribute. strangely this is not listed as one of the options in Quartus help.
That looks more promising. I'll go and give it a try.
Thanks for the help,
Richard
edit: works a treat!
