I just find that there exist two strange path in TimeQuest report which show that:
From Node & To Node are the same register, but launch clock & latch clock are different, pls see the detailed info below:
Info: Path# 2: Setup slack is 5.644
Info: ===================================================================
Info: From Node : FreqMeasure_NiosII:inst|freqmeasure_wholesystem_inst:the_freqmeasure_wholesystem_inst|freqmeasure_wholesystem:the_freqmeasure_wholesystem|FREQMeasure_StrobeGenerator:U1|OUT_STROBE
Info: To Node : FreqMeasure_NiosII:inst|freqmeasure_wholesystem_inst:the_freqmeasure_wholesystem_inst|freqmeasure_wholesystem:the_freqmeasure_wholesystem|FREQMeasure_StrobeGenerator:U1|OUT_STROBE
Info: Launch Clock : OUT_STROBE (INVERTED)
Info: Latch Clock : FreqMeasure_NiosII:inst|pll:the_pll|altpllpll:the_pll|altpll:altpll_component|_clk0 Info:
Info: Data Arrival Path:
Info:
Info: Total (ns) Incr (ns) Type Element
Info: ========== ========= == ==== ===================================
Info: 500000.000 500000.000 launch edge time
Info: 500000.000 0.000 F clock network delay
Info: 500000.000 0.000 FF CELL inst|the_freqmeasure_wholesystem_inst|the_freqmeasure_wholesystem|U1|OUT_STROBE|regout
Info: 500002.458 2.458 FF IC inst|the_freqmeasure_wholesystem_inst|the_freqmeasure_wholesystem|U1|OUT_STROBE~clkctrl|inclk
Info: 500002.458 0.000 FF CELL inst|the_freqmeasure_wholesystem_inst|the_freqmeasure_wholesystem|U1|OUT_STROBE~clkctrl|outclk
Info: 500004.396 1.938 FF IC inst|the_freqmeasure_wholesystem_inst|the_freqmeasure_wholesystem|U1|Selector9~9|datad
Info: 500004.602 0.206 FF CELL inst|the_freqmeasure_wholesystem_inst|the_freqmeasure_wholesystem|U1|Selector9~9|combout
Info: 500004.602 0.000 FF IC inst|the_freqmeasure_wholesystem_inst|the_freqmeasure_wholesystem|U1|OUT_STROBE|datain
Info: 500004.710 0.108 FF CELL FreqMeasure_NiosII:inst|freqmeasure_wholesystem_inst:the_freqmeasure_wholesystem_inst|freqmeasure_wholesystem:the_freqmeasure_wholesystem|FREQMeasure_StrobeGenerator:U1|OUT_STROBE
Info:
Info: Data Required Path:
Info:
Info: 500010.000 500010.000 latch edge time
Info: 500010.314 0.314 R clock network delay
Info: 500010.354 0.040 uTsu FreqMeasure_NiosII:inst|freqmeasure_wholesystem_inst:the_freqmeasure_wholesystem_inst|freqmeasure_wholesystem:the_freqmeasure_wholesystem|FREQMeasure_StrobeGenerator:U1|OUT_STROBE
Info:
Info: Data Arrival Time : 500004.710
Info: Data Required Time : 500010.354
Info: Slack : 5.644
Info:
2 5.644
I have reviewed my RTL code & do some observation, the launch clock & latch clock should both be FreqMeasure_NiosII:inst|pll:the_pll|altpllpll:the_pll|altpll:altpll_component|_clk0. P.S. OUT_STROBE is generated from FreqMeasure_NiosII:inst|pll:the_pll|altpllpll:the_pll|altpll:altpll_component|_clk0. Any mistake I make?
This is what I think is happening in your design: You've had threads with a clock created by a divide-by-2 register. (I hope you checked out my posts that I referred you to with caveats for creating clocks that way.) I suspect that the register, which has a name ending in "OUT_STROBE", is a divide-by-2 register driving the clock signal constrained by the clock called "OUT_STROBE". If so, you have a clock-as-data-analysis situation. If the same signal is used as both a clock and as a data signal, the reporting can be confusing. A report like yours is given for the feedback path with the divide-by-2 register as both source and destination. The feedback path is a data path for the same signal that is used as a clock for other registers. That results in the confusing reporting for clock-as-data analysis. TimeQuest does it the way it does to be consistent with PrimeTime (as I understand it).
This is the first possibility I thought of, but it probably isn't what you have in your design: The same register can have more than one clock. An example is a register with clocks selected by a mux. Unless you tell TimeQuest otherwise (typically with a set_clock_groups command), TimeQuest will assume that one of the mux input clocks can be selected at the time of the launching edge and another mux input clock can be selected at the time of the latching edge.- Mark as New
You are absolutely correct in the first description.
So what should I do? Or just let it be?- Mark as New
As far as the timing analysis is concerned, the reporting is correct. As long as the slack is positive, you are OK.
As far as whether you followed good design practices, I still recommend that you review my posts at http://www.alteraforum.com/forum/showthread.php?t=754 if you haven't already.- Mark as New
I have read it twice. :)
But can't understand clearly. It's hard to understand for me(a newer), but I will remember it and when I encounter similar problem, I'll return back to read it. Thanks... hmm...could you teach me some other ways to express my thanks :) I feel it's not enough to express my appreciation by just a simple 'thanks' word. Thanks again anyway. haha
