17252 Discussions
structural verilog with base library parts?
Is there a library of base parts (like a parameterized LAB for example?) that I can instantiate manually and maybe locate at a particular row,col address inside a device?
lefty
Designing with primitives is generally discouraged, as you are unlikely to do a better job than the synthesis tool. Is there a reason for wanting to use primitives?
there is this document from 11 years ago: https://www.altera.com/en_us/pdfs/literature/ug/ug_low_level.pdf
and memories: https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_ram_rom.pdf
If you want to lock them to specific locations, you need to use logiclock constraints. Guide here: http://www.alterawiki.com/uploads/6/61/tips_for_incrementalcompilation_logiclock.pdf
Basically, all of this is much much slower, and likely less efficient than writing HDL. Let alone being terrible for anyone else to read.
Thanks for fantastic information. My interest is just for learning purposes. From your advice I may not be able to place because I'm using the free version which has logiclock nobbled?
--- Quote Start ---
--- Quote End ---
