17268 Discussions
syntax error at medias_2.vhd(31) near text "in"; expecting "(",
I've got this error in the following code, what's wrong in it? Thanks in advance.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_signed.ALL;
use IEEE.STD_LOGIC_arith.ALL;
use ieee.numeric_std.all;
use IEEE.STD_LOGIC_TEXTIO.ALL;
use IEEE.STD_LOGIC_UNSIGNED.all;
--package imagens is
--type image_array is array(0 to 49, 0 to 49) of unsigned(7 downto 0);
--type image_derivadas is array(0 to 49, 0 to 49) of unsigned (8 downto 0);
--type image_19bits is array (0 to 49, 0 to 49) of unsigned (18 downto 0);
--end package imagens;
entity medias_2 is
port(
--divisor: in image_19bits;
--dividendo: in image_derivadas;
uk2: in image_19bits;
vk2: in image_19bits;
mediau2: out image_19bits;
mediav2: out image_19bits
); end medias_2;
architecture behaviour of medias_1 is
--FOR
for x in 1 to 48 loop
for y in 1 to 48 loop
--mediami[j] = (mi(x-1,y-1)+mi(x-1,y)+mi(x-1,y+1)+mi(x,y-1)+mi(x,y)+mi(x,y+1)+mi(x+1,y-1)+mi(x+1,y)+mi(x+1,y+1))/9;
--mediani[j] = (ni(x-1,y-1)+ni(x-1,y)+ni(x-1,y+1)+ni(x,y-1)+ni(x,y)+ni(x,y+1)+ni(x+1,y-1)+ni(x+1,y)+ni(x+1,y+1))/9;
mediau2(x,y) <= (uk2(x-1,y-1)+uk2(x-1,y)+uk2(x-1,y+1)+uk2(x,y-1)+uk2(x,y)+uk2(x,y+1)+uk2(x+1,y-1)+uk2(x+1,y)+uk2(x+1,y+1))/9;
mediav2(x,y) <= (vk2(x-1,y-1)+vk2(x-1,y)+vk2(x-1,y+1)+vk2(x,y-1)+vk2(x,y)+vk2(x,y+1)+vk2(x+1,y-1)+vk2(x+1,y)+vk2(x+1,y+1))/9;
end loop;
end loop;
mediau2(0,y) <= (uk2(x-1,0)+uk2(x-1,1)+uk2(x,0)+uk2(x,1)+uk2(x+1,0)+uk2(x+1,1))/6;
mediau2(49,y) <= (uk2(x-1,48)+uk2(x-1,49)+uk2(x,48)+uk2(x,49)+uk2(x+1,48)+uk2(x+1,49))/6;
mediav2(0,y) <= (vk2(x-1,0)+vk2(x-1,1)+vk2(x,0)+vk2(x,1)+vk2(x+1,0)+vk2(x+1,1))/6;
mediav2(49,y) <= (vk2(x-1,48)+vk2(x-1,49)+vk2(x,48)+vk2(x,49)+vk2(x+1,48)+vk2(x+1,49))/6;
end loop;
mediau2(0,y) <= (uk2(0,y-1)+uk2(0,y)+uk2(0,y+1)+uk2(1,y-1)+uk2(1,y)+uk2(1,y+1))/6;
mediau2(49,y) <= (uk2(48,y-1)+uk2(48,y)+uk2(48,y+1)+uk2(49,y-1)+uk2(49,y)+uk2(49,y+1))/6;
mediav2(0,y) <= (vk2(0,y-1)+vk2(0,y)+vk2(0,y+1)+vk2(1,y-1)+vk2(1,y)+vk2(1,y+1))/6;
mediav2(49,y) <= (vk2(48,y-1)+vk2(48,y)+vk2(48,y+1)+vk2(49,y-1)+vk2(49,y)+vk2(49,y+1))/6;
end loop;
mediau2(0,0)<= (uk2(0,0)+uk2(0,1)+uk2(1,0)+uk2(1,1))/4;
mediau2(0,49)<= (uk2(0,48)+uk2(0,49)+uk2(1,48)+uk2(1,49))/4;
mediau2(49,0)<= (uk2(48,0)+uk2(48,1)+uk2(49,0)+uk2(49,1))/4;
mediau2(49,49)<= (uk2(48,48)+uk2(48,49)+uk2(49,48)+uk2(49,49))/4;
mediav2(0,0)<= (vk2(0,0)+vk2(0,1)+vk2(1,0)+vk2(1,1))/4;
mediav2(0,49)<= (vk2(0,48)+vk2(0,49)+vk2(1,48)+vk2(1,49))/4;
mediav2(49,0)<= (vk2(48,0)+vk2(48,1)+vk2(49,0)+vk2(49,1))/4;
mediav2(49,49)<= (vk2(48,48)+vk2(48,49)+vk2(49,48)+vk2(49,49))/4;
end process;
end behaviour;
Theres probably a ( missing near line 31.
Also, your problem in your other post is probably because you included std_logic_arith - please delete this library.
--- Quote Start ---
--- Quote End ---
But where in line 31 i put this "("?
I've also tried to delete std_logic_arith that was defined in other part of the code, still don't work.
I dont know, as line 31 in the code you posted is a blank line.
This is a pretty simple error to find and fix yourself. Just get a decent text editor - they all do bracket matching to ensure each ( has a corresponding )
And again - I cant see your real code, so no idea whether removing std_logic_arith is going to help (but you shouldnt use it anyway)
--- Quote Start ---
--- Quote End ---
Line 31 is the one where "for x in 1 to 48" appears for the first time.
Instead of posting fairly useless information, why not post the real code?
Or even better - fix this syntax error yourself. You know what the error is - theres a bracket missing. Why not try looking in the lines above?
--- Quote Start ---
--- Quote End ---
It's because i don't know how to fix it. It doensn't make sense for me a bracket missing anywhere.
Without the code - I dont know what you expect us to do..
--- Quote Start ---
--- Quote End ---
the code goes as follows:
1- library IEEE;
2- use IEEE.STD_LOGIC_1164.ALL;
3- use IEEE.STD_LOGIC_signed.ALL;
4- --use IEEE.STD_LOGIC_arith.ALL;
5- use ieee.numeric_std.all;
6- use IEEE.STD_LOGIC_TEXTIO.ALL;
7- use IEEE.STD_LOGIC_UNSIGNED.all;
8- --package imagens is
9- --type image_array is array(0 to 49, 0 to 49) of unsigned(7 downto 0);
10- --type image_derivadas is array(0 to 49, 0 to 49) of unsigned (8 downto 0);
11- --type image_19bits is array (0 to 49, 0 to 49) of unsigned (18 downto 0);
12- --end package imagens;
13-
14- entity medias_2 is
15- port(
16-
17- --divisor: in image_19bits;
18- --dividendo: in image_derivadas;
19- uk2: in image_19bits;
20- vk2: in image_19bits;
21- mediau2: out image_19bits;
22- mediav2: out image_19bits
23-
24- ); end medias_2;
25-
26-
27-
28- architecture behaviour of medias_1 is
29-
30- --FOR
31- for x in 1 to 48 loop
32- for y in 1 to 48 loop
33- --mediami[j] = (mi(x-1,y-1)+mi(x-1,y)+mi(x-1,y+1)+mi(x,y-1)+mi(x,y)+mi(x,y+1)+mi(x+1,y-1)+mi(x+1,y)+mi(x+1,y+1))/9;
34-
35- --mediani[j] = (ni(x-1,y-1)+ni(x-1,y)+ni(x-1,y+1)+ni(x,y-1)+ni(x,y)+ni(x,y+1)+ni(x+1,y-1)+ni(x+1,y)+ni(x+1,y+1))/9;
36- mediau2(x,y) <= (uk2(x-1,y-1)+uk2(x-1,y)+uk2(x-1,y+1)+uk2(x,y-1)+uk2(x,y)+uk2(x,y+1)+uk2(x+1,y-1)+uk2(x+1,y)+uk2(x+1,y+1))/9;
37- mediav2(x,y) <= (vk2(x-1,y-1)+vk2(x-1,y)+vk2(x-1,y+1)+vk2(x,y-1)+vk2(x,y)+vk2(x,y+1)+vk2(x+1,y-1)+vk2(x+1,y)+vk2(x+1,y+1))/9;
38-
39- end loop;
40- end loop;
41-
42- for x in 1 to 48 loop
43- mediau2(0,y) <= (uk2(x-1,0)+uk2(x-1,1)+uk2(x,0)+uk2(x,1)+uk2(x+1,0)+uk2(x+1,1))/6;
44- mediau2(49,y) <= (uk2(x-1,48)+uk2(x-1,49)+uk2(x,48)+uk2(x,49)+uk2(x+1,48)+uk2(x+1,49))/6;
45- mediav2(0,y) <= (vk2(x-1,0)+vk2(x-1,1)+vk2(x,0)+vk2(x,1)+vk2(x+1,0)+vk2(x+1,1))/6;
46- mediav2(49,y) <= (vk2(x-1,48)+vk2(x-1,49)+vk2(x,48)+vk2(x,49)+vk2(x+1,48)+vk2(x+1,49))/6;
47-
48- end loop;
49-
50- for y in 1 to 48 loop
51- mediau2(0,y) <= (uk2(0,y-1)+uk2(0,y)+uk2(0,y+1)+uk2(1,y-1)+uk2(1,y)+uk2(1,y+1))/6;
52- mediau2(49,y) <= (uk2(48,y-1)+uk2(48,y)+uk2(48,y+1)+uk2(49,y-1)+uk2(49,y)+uk2(49,y+1))/6;
53- mediav2(0,y) <= (vk2(0,y-1)+vk2(0,y)+vk2(0,y+1)+vk2(1,y-1)+vk2(1,y)+vk2(1,y+1))/6;
54- mediav2(49,y) <= (vk2(48,y-1)+vk2(48,y)+vk2(48,y+1)+vk2(49,y-1)+vk2(49,y)+vk2(49,y+1))/6;
55-
56- end loop;
57-
58- mediau2(0,0)<= (uk2(0,0)+uk2(0,1)+uk2(1,0)+uk2(1,1))/4;
59- mediau2(0,49)<= (uk2(0,48)+uk2(0,49)+uk2(1,48)+uk2(1,49))/4;
60- mediau2(49,0)<= (uk2(48,0)+uk2(48,1)+uk2(49,0)+uk2(49,1))/4;
61- mediau2(49,49)<= (uk2(48,48)+uk2(48,49)+uk2(49,48)+uk2(49,49))/4;
62- mediav2(0,0)<= (vk2(0,0)+vk2(0,1)+vk2(1,0)+vk2(1,1))/4;
63- mediav2(0,49)<= (vk2(0,48)+vk2(0,49)+vk2(1,48)+vk2(1,49))/4;
64- mediav2(49,0)<= (vk2(48,0)+vk2(48,1)+vk2(49,0)+vk2(49,1))/4;
65- mediav2(49,49)<= (vk2(48,48)+vk2(48,49)+vk2(49,48)+vk2(49,49))/4;
66-
67- end process;
68- end behaviour;
This still cannot be the real code because there is too much missing to create the error you listed in the thread title.
