I'm trying to do something similar to the example in Quartus 9.0 Handbook, Volume 3 Chapter 17: Design Debugging Using In-System Sources and Probes - Example 17–1. Tcl Script Procedures for Reading and Writing to the...
I'm having problems related to the int2bits procedure When I first tried to run it, I got invalid command name "int2bits", as if the proc is undefined I found this at http://wiki.tcl.tk, so I added it: proc int2bits {i} { # returns a bitslist, e.g. int2bits 10 => {1 0 1 0} set res "" while {$i>0} { set res [expr {$i%2}]$res set i [expr {$i/2}] } if {$res==""} {set res 0} split $res "" } Now the problem seems to be that int2bits returns something like 1 0 1 0, when it appears that the proper form needed in the write would be 1010 e.g. this form works write_source_data -instance_index 0 -value [0010001000100010001000] where this doesn't (it writes to the source, but something other than what I want) write_source_data -instance_index 0 -value [0 0 1 0 0 0 1 0 0 0 1 0 0 0 1 0 0 0 1 0 0 0] nor write_source_data -instance_index 0 -value [int2bits 0x88888] What is the proper form of the int2bits proc needed to make this work correctly? Or is there an alternative to int2bits to get the binary form needed?Link Copied
See http://tmml.sourceforge.net/doc/tcl/expr.html. As you can see expr adds a space to produce a list as a result. Check http://tcl.projectforum.com/young/251 for tips about handling strings and the difference with lists in TCL.
OK, so this works:
write_source_data -instance_index 0 -value [regsub -all " " [int2bits 0x88888] ""] So does modifying int2bits to do the regsub after the split. I still think the example in the Quartus manual is confusing at best, and probably wrong. Thanks for the help. :)
