17249 Discussions
test bench from a program
how the test bench to run this program on ModelSim Altera?
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
entity clkdiv is
generic ( n : integer :=10);
port (
clkin : in std_logic;
clkout : out std_logic);
end clkdiv;
architecture arc of clkdiv is
signal clk_tmp : std_logic := '0';
signal cnt : integer := 0 ;
begin
process (clkin,cnt) begin
if (clkin'event and clkin='1') then
cnt <= cnt + 1;
if ( cnt = n-1 ) then
clk_tmp <= not clk_tmp;
cnt <= 0;
end if;
end if;
end process;
clkout <= clk_tmp ;
end arc;
You just need a process that generates the clock for the clkin port. Any good tutorial or book about VHDL simulation should tell you how to do it.
