Sorry to bother you. When I merge a .qxp file from a project into the new project through setting new design partition in it, the following error about Quartus II shows: Internal Error: Sub-system: BPM, File: /quartus/db/bpm/bpm_boundary_port_manager_impl.cpp, Line: 9229 bp->get_fanout_count() == 0 Stack Trace: 0x7688: BPM_BOUNDARY_PORT_MANAGER_IMPL::delete_bp + 0xa8 (db_bpm) 0x39fb4: BPM_BOUNDARY_PORT_HIDE::process_gnd_ports + 0x264 (db_bpm) 0x3d107: BPM_BOUNDARY_PORT_HIDE::post_hide_operations + 0x7 (db_bpm) 0x12b8b: BPM_BOUNDARY_PORT_MANAGER_IMPL::hide_boundary_ports + 0x47b (db_bpm) 0x59e1e: AMERGE_MERGER_OP::perform_post_merge_operations + 0x59e (atm_amerge) 0x470b: amerge_combine_netlist + 0x2db (atm_amerge) 0x48f0: _amerge_start + 0x10 (atm_amerge) 0x35f92: qatm_merge_netlist + 0x112 (quartus_cdb) 0x1918b: qatm_import_database + 0xdcb (quartus_cdb) 0x1fba2: QATM_FRAMEWORK::execute + 0x1062 (quartus_cdb) 0xff71: qexe_get_command_line + 0x14c1 (comp_qexe) 0x12474: qexe_process_cmdline_arguments + 0x3d4 (comp_qexe) 0x12563: qexe_standard_main + 0x83 (comp_qexe) 0x15dba: qatm_main + 0x4a (quartus_cdb) 0x1c51: msg_main_thread + 0x11 (CCL_MSG) 0x1be8: _thr_final_wrapper + 0x8 (ccl_thr) 0x1bc5: msg_thread_wrapper + 0x85 (CCL_MSG) 0x443a: mem_thread_wrapper + 0x4a (ccl_mem) 0x2b5d1: msg_exe_main + 0x81 (CCL_MSG) 0x1b3fc: _main + 0x1c (quartus_cdb) 0x39e04: __chkstk + 0x184 (quartus_cdb) 0x17076: RegisterWaitForInputIdle + 0x48 (kernel32) End-trace Quartus II 32-bit Version 11.1 Build 173 11/01/2011 SJ Full Version What does that mean? Thanks very much for your help!Link Copied
Try first to delete the db and incremental_db folders in your project and recompile it. If it doesn't work, file an SR with Altera support, it is an internal error and there isn't a lot we can do about it.
You could try and install the latest service pack too, it may have fixed the bug.
