vriable length counter
hello,
im trying to do a simple morsecode :
library ieee;
use ieee.std_logic_1164.all;
entity morse is
port ( sw : in std_logic_vector(2 downto 0);
e : in std_logic;
clock : in std_logic;
led : out std_logic_vector(6 downto 0));
end morse;
architecture behavioral of morse is
signal clk :std_logic:='0';
signal sr : std_logic_vector(15 downto 0):="0000000000000000";
signal n : integer:=0;
begin
halfsecclk : process(clock)
variable count : integer :=0;
begin
if clock'event and clock='1' then
count:=count + 1;
if count = 2 then
count :=0;
clk <= not clk;
end if;
end if;
end process;
muxes : process(e)
begin
if e'event and e='0' then
case sw is
when "000" =>
sr <= "0000000000011101";
n <=6 ;
when "001" =>
sr <= "0000000101010111";
n <=10 ;
when "010" =>
sr <= "0000010111010111";
n <= 12;
when "011" =>
sr <= "0000000001010111";
n <= 8;
when "100" =>
sr <= "0000000000000001";
n <= 2;
when "101" =>
sr <= "0000000101110101";
n <= 10;
when "110" =>
sr <= "0000000101110111";
n <= 10;
when "111" =>
sr <= "0000000001010101";
n <= 8;
when others => null;
end case;
end if;
end process;
counter : process(clk)
variable cnt : integer:=0;
begin
if rising_edge(clk) then
if sr(0)='0' then
led <= "1111111";
elsif sr(0)='1' then
led <= "0111111";
end if;
sr<="0" & sr(15 downto 1);
end if;
end process;
end behavioral;
what i faild to do is to make the counter process shift the (sr) shift register by (n) times then stop and waits for the next value of sw is entered, i have tried many ideas but it didnt worked as i want it to.
any suggestions please ?
thanks in advance
--- Quote Start ---
--- Quote End ---
- Did you simulate the design? If so, what were the results? If not, get one and try it.
- What else did you try? What didn't work out as you wanted it to?
Kevin Jennings
I'll try to explain more on what i want , depending on the input (sw) the register (sr) will assigned a collection of bits, also the signal (n) will be assigned an integer value which is the number of bits in the register, all of this will happen in the first process.
in the second process which is clocked i want it to shift the (sr) register for each rising edge clock (n) times.
here is what I've done:
begin
if n/=0 then
if sr(0)='0' then
led <= "1111111";
led <= "0111111";
end if;
n<=n-1;
end if;
end if;
end process;
end behavioral;
It's totaly wrong since two processes driving sr and n.
I know what I've done is stuped but I'm new to the vhdl and i came from another enviroment.
--- Quote Start ---
--- Quote End ---
I would prefer that you answer the questions I posed instead...repeated here since they are still necessary.
--- Quote Start ---
<snip of partial code>
--- Quote End ---
OK, so you know what the problem is, you have two processes each driving a couple of signals...one would think then you know what to do which is to combine them into one process (hint: that's the answer)
--- Quote Start ---
--- Quote End ---
It sounds like you know what the problem is, you can't have two drivers for one signal. So what is your question?
Kevin Jennings
I've got it, thank you K J :)
can you post your final morse code here? I am trying to do something similar. but cant figure it out
