- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
hello.
there are some warnings occured during compilation.i do not know how to deal with the warning. Warning: Latch "calCD" has unsafe behavior Warning: Ports D and ENA on the latch are fed by the same signal CurloopCal[1]. here is the code: always @ (posedge clk125M_i or posedge AsyRst_i) begin if(AsyRst_i) begin CurloopCal <=0; end else if(TimeEn_i) begin if(CurloopCal ==0) begin if(CureadFin_i) begin CurloopCal <=1; end else begin CurloopCal <=0; end end else begin if(CurloopCal <6) begin CurloopCal <= CurloopCal+1; end else if(CurloopCal ==6) begin CurloopCal <=0; end else begin CurloopCal <=0; end end end else begin CurloopCal <=0; end end always @(CurloopCal) begin case (CurloopCal) 4'd0:begin calCP =0; calCI =0; calCD =0; end 4'd1:begin Cerr0 = Curexp - Curfbk; end 4'd2:begin delce = Cerr0-Cerr1; end 4'd3:begin sumce <= sumce+Cerr0; Cerr1 <= Cerr0; calCP =1; calCI =1; calCD =1; end 4'd4:begin RsutCPI = (RsutCP>>4)+(RsutCI>>4); end 4'd5:begin RsutCPID0 = RsutCPI+(RsutCD>>4); end default:begin end endcase end thank you!!コピーされたリンク
2 返答(返信)
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
substitute your instruction:
default:begin end with default: begin RsutCPID0<=1'bx; Add all the signals that are defined in the procedural block end In the sensitivity list : always @(CurloopCal) add the signals that are on the right side of the assignments such as: Cerr0 always @(CurloopCal,Cerr0) This won't solve all the problems. As example you write: sumce <= sumce+Cerr0; That can waork only if a register holds the sumce value and the procedural block is sychronized with the clock. I suggest to read a book on Verilog for synthesis.- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
I suggest you use V2K style (atleast) and use always @(*) for combinatorial logic blocks. That would resolve your sensitivity list issues. With SystemVerilog you are better off using always_comb. See: http://www.slideshare.net/fpgacentral/upgrading-to-system-verilog-for-fpga-designs-srinivasan-venkataramanan-cvc for the slides I presented at FPGACamp in Bangalore on SystemVerilog for FPGA designs. HTH Srini www.cvcblr.com/blog
