the "latch" problem
hello.
there are some warnings occured during compilation.i do not know how to deal with the warning.
Warning: Latch "calCD" has unsafe behavior
Warning: Ports D and ENA on the latch are fed by the same signal CurloopCal[1].
here is the code:
always @ (posedge clk125M_i or posedge AsyRst_i)
begin
if(AsyRst_i)
begin
CurloopCal <=0;
end
else if(TimeEn_i)
begin
if(CurloopCal ==0)
begin
if(CureadFin_i)
begin
CurloopCal <=1;
end
else
begin
CurloopCal <=0;
end
end
else
begin
if(CurloopCal <6)
begin
CurloopCal <= CurloopCal+1;
end
else if(CurloopCal ==6)
begin
CurloopCal <=0;
end
else
begin
CurloopCal <=0;
end
end
end
else
begin
CurloopCal <=0;
end
end
always @(CurloopCal)
begin
case (CurloopCal)
4'd0:begin
calCP =0;
calCI =0;
calCD =0;
end
4'd1:begin
Cerr0 = Curexp - Curfbk;
end
4'd2:begin
delce = Cerr0-Cerr1;
end
4'd3:begin
sumce <= sumce+Cerr0;
Cerr1 <= Cerr0;
calCP =1;
calCI =1;
calCD =1;
end
4'd4:begin
RsutCPI = (RsutCP>>4)+(RsutCI>>4);
end
4'd5:begin
RsutCPID0 = RsutCPI+(RsutCD>>4);
end
default:begin end
endcase
end
thank you!!
substitute your instruction:
default:begin end
with
default:
begin
RsutCPID0<=1'bx;
Add all the signals that are defined in the procedural block
end
In the sensitivity list : always @(CurloopCal)
add the signals that are on the right side of the assignments such as: Cerr0
always @(CurloopCal,Cerr0)
This won't solve all the problems. As example you write: sumce <= sumce+Cerr0;
That can waork only if a register holds the sumce value and the procedural block is sychronized with the clock.
I suggest to read a book on Verilog for synthesis.
I suggest you use V2K style (atleast) and use always @(*) for combinatorial logic blocks. That would resolve your sensitivity list issues. With SystemVerilog you are better off using always_comb. See:
http://www.slideshare.net/fpgacentral/upgrading-to-system-verilog-for-fpga-designs-srinivasan-venkataramanan-cvc
for the slides I presented at FPGACamp in Bangalore on SystemVerilog for FPGA designs.
HTH
Srini
www.cvcblr.com/blog
