Hi, um kinda new to quartus ,,
i wanna know what do the options in the trigger panel in signaltap means , Trigger in , Trigger out , ram size , segement size ,, etc also i want to capture the value of std logic vector in my design when its ready signal is high so how can i do this ? is there any documentation about the signaltap , may be a description or how it works ? Thanks in advance.Link Copied
Trigger in: an input signal from an I/O pin or internal to design used essentially as "trigger 0", the first trigger condition looked at by the tool
Trigger out: output signal indicating that a trigger has occurred RAM size: number of samples of captured data you want to store in on-chip RAM; the more samples and signals monitored, the more OCRAM required segment size: divide up the captured data buffer into evenly sized segments, good for observing signal behavior in the design for a trigger that repeats This is all documented here in volume 3 of the Quartus Prime handbook: https://www.altera.com/products/design-software/fpga-design/quartus-prime/support.html You can get detailed training on this here: https://www.altera.com/support/training/catalog.html?coursetype=online&language=english&keywords=signaltap As for your capture question, you just set up a basic AND trigger to capture data when the signal goes high. Look through the documentation and training for details.- Mark as New
--- Quote Start --- Trigger in: an input signal from an I/O pin or internal to design used essentially as "trigger 0", the first trigger condition looked at by the tool Trigger out: output signal indicating that a trigger has occurred RAM size: number of samples of captured data you want to store in on-chip RAM; the more samples and signals monitored, the more OCRAM required segment size: divide up the captured data buffer into evenly sized segments, good for observing signal behavior in the design for a trigger that repeats This is all documented here in volume 3 of the Quartus Prime handbook: https://www.altera.com/products/design-software/fpga-design/quartus-prime/support.html You can get detailed training on this here: https://www.altera.com/support/training/catalog.html?coursetype=online&language=english&keywords=signaltap As for your capture question, you just set up a basic AND trigger to capture data when the signal goes high. Look through the documentation and training for details. --- Quote End --- Thanks alot for your help
