ultrasonic sensor in VHDL
名誉分销商 II
4,545 次查看
hi everyone, i have some problems in testing the following code, by knowing that i found this code in this forums, can anybody test it and tell me if he found the same problems and how to solve it.
the code is in site https://github.com/xesscorp/xula/blo...lib/hcsr04.vhd (https://github.com/xesscorp/xula/blob/master/fpga/xula_lib/hcsr04.vhd) and thnx in advance.
[h=1][/h]
0 项奖励
9 回复数
名誉分销商 II
1,748 次查看
Instead of expecting others to do your work for you, why not tell us what problems you are having?
0 项奖励
名誉分销商 II
1,748 次查看
--- Quote Start ---
--- Quote End ---
i'am not telling you to do my work i'am just asking if have a problems in compiling the program, and depend on your answer i will know what is the problem, and sorry for disturbing you sir.
0 项奖励
名誉分销商 II
1,748 次查看
What problems are you having with it?
0 项奖励
名誉分销商 II
1,748 次查看
Please be specific on the question, that will save your time & you can expect a quick response.
0 项奖励
名誉分销商 II
1,748 次查看
--- Quote Start ---
--- Quote End ---
hi, sorry for being too late, i have this problems when compiling the previous VHDL code http://www.alteraforum.com/forum/attachment.php?attachmentid=12276&stc=1 :(:confused::confused:
0 项奖励
名誉分销商 II
1,748 次查看
The problem is that Quartus is made by altera for altera parts. The code you have downloaded is for a Xilinx board.
0 项奖励
名誉分销商 II
1,748 次查看
--- Quote Start ---
--- Quote End ---
really!!!!!!! but how to know that is in xillinix, it is possible to modified it to altera vhdl?????
0 项奖励
名誉分销商 II
1,748 次查看
Its in the Xula repository, and with 30s of searching I found it had a Xilinx chip.
What gave it away from your post was the failure to find the UNISIM library - which is a Xilinx primitives simulation library.
To get it working for Altera, you'll have to strip out all references to UNISIM.
If all you want is this one file - just delete the unisim library.
0 项奖励
名誉分销商 II
1,748 次查看
:)thnx for helping me i appreciate that, i will try to modify it and see if i get any result. :)
--- Quote Start ---
--- Quote End ---
0 项奖励
回复
