Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Pausing target processor: not responding. Resetting and trying again: FAILED Leaving target processor paused hello everybody... above one is the problem i have faced in running the nios II ide using quartus II 7.2sp2....for the hello world example..pls help me to clear this...Link Copied
the problem is not your usb blaster. but your nios system, that does not start up corectly.
check the the start up adress, reset's, memory , clocks and so on.- Mark as New
--- Quote Start --- the problem is not your usb blaster. but your nios system, that does not start up corectly. check the the start up adress, reset's, memory , clocks and so on. --- Quote End --- hai..thank you for the reply... i am using the hello world example only...pls help me
What hardware are you working with? Is it an Altera board or something you don't know is good to start with?
