Are there any tutorial about how to create a mif file via file->new->mif from the tool bar? For example, If I need to initialize RAM/ROM with
addr value 0 00 1 01 2 11 3 10 how should I choose the number of words and word size and fill in numbers? Thanks.Link Copied
a mif is just a text file, you can create it with any editor you like.
As for the file format, if you go into the Quartus help menu, click search and type "mif", the first result is a description of the format, with an example.- Mark as New
lpm_ram_dq is used to create a RAM. Is there a similar way to create a ROM?
I don't know if there is a LPM ROM primitive, but if you just use the RAM primitive and connect the write signal to always 0, you get a ROM.
