17252 Discussions
(vcom-1253) No default binding for component instance "counter : a_74161".
Hi all,
I am trying to simulate a simple counter in model sim using a counter implemented using the a_74161 counter from altera’s maxplus2 library: C:\altera\13.0\quartus\libraries\vhdl\altera
Simulating the design in quartus works fine using the University Program VWF – so the design appears to work - see attachment.
Trying to simulate the counter in multisim I don’t get far: When I compilate my file in multisim:
vcom -reportprogress 300 -bindAtCompile -work work C:/altera/13.0/work_2/z_74161.vhd
I get:
# Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012# -- Loading package STANDARD# -- Loading package TEXTIO# -- Loading package std_logic_1164# -- Loading package maxplus2# -- Compiling entity z_74161# -- Compiling architecture z_74161_arch of z_74161# ** Warning: [1] C:/altera/13.0/work_2/z_74161.vhd(66): (vcom-1253) No default binding for component instance "counter : a_74161".# (No entity named "a_74161" was found.)
Code:
LIBRARY ieee;
USE ieee.std_logic_1164.all;
LIBRARY altera;
USE altera.maxplus2.ALL;
ENTITY z_74161 IS
port ( clk: in STD_LOGIC;
ldn: in STD_LOGIC;
clrn: in STD_LOGIC;
enp: in STD_LOGIC;
ent: in STD_LOGIC;
d: in STD_LOGIC;
c: in STD_LOGIC;
b: in STD_LOGIC;
a: in STD_LOGIC;
qd: out STD_LOGIC;
qc: out STD_LOGIC;
qb: out STD_LOGIC;
qa: out STD_LOGIC;
rco: out STD_LOGIC);
END z_74161;
ARCHITECTURE z_74161_arch OF z_74161 IS
BEGIN
counter: a_74161
PORT MAP(
clk => clk,
ldn => '1',
clrn => '1',
enp => '1',
ent => '1',
d => '0',
c => '0',
b => '0',
a => '0',
qd => qd,
qc => qc,
qb => qb,
qa => qa,
rco => rco
END architecture z_74161_arch;
I have also compiled the “C:\altera\13.0\quartus\libraries\vhdl\altera” into “C:\altera\13.0\work_2\simulation\modelsim\altera” (see attachment).
Any help is appreciated
br /mattias
Hi all,
I couldnt solve this.
Instead I copied the underlying 74161.bdf model and created my own vhdl file from it to use as a component (note: you have to include command: "library altera" to secure "carry" is recognized.
This solved the need for having to include any libraries that are not part of modelsims precompiled libraries.
Not a solution but a workaround.
Its a pitty that not all libraries are precompiled in modelsim.
br /mattias
