17261 Discussions
(vcom-1600) No feasible entries for subprogram
Dear Good people,
I was using following code while simulating it through modelsim, it shows following error : (vcom-1600) No feasible entries for subprogram "avalon_write". Can you guys please give me a solution? Thanks
Here is the code:
library IEEE;
library work;
library std;
library mm_master_bfm_0;
--library slave_0;
use std.textio.all;
use IEEE.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use IEEE.numeric_std.all;
use IEEE.math_real.all;
use work.all;
use mm_master_bfm_0.altera_avalon_mm_master_bfm_vhdl_p kg.all;
entity test_program_new is
generic
AV_ADDRESS_W : natural := 4;
AV_SYMBOL_W : natural := 8;
AV_NUMSYMBOLS : natural := 4;
AV_DATA_W : natural := 32;
--VERBOSITY : VERBOSITY_INFO;
INDEX_ZERO : natural := 0;
ADDR_MEM_CTRL : natural := 16;
ADDR_CASA_DUMMY : std_logic_vector (AV_ADDRESS_W -1 downto 0) := (others => '0'));
-- ADDR_MEM_CTRL_CONTROL_R : natural := (0*4);
-- ADDR_MEM_CTRL_PAYLOAD_ADDR_R : natural := (1*4);
-- ADDR_MEM_CTRL_CONFIG_ADDR_R : natural := (2*4);
-- ADDR_MEM_CTRL_CONFIG_ENTRY_NR_R : natural := (3*4);
-- ADDR_MEM_CTRL_PAYLOAD_SIZE_R : natural := (4*4);
-- ADDR_MEM_CTRL_ANC_PER_LINE_SIZE_R : natural := (5*4);
-- ADDR_MEM_CTRL_DID_SDID_R : natural := (6*4)
port (
clk : in std_logic ;
reset : in std_logic
end test_program_new;
architecture behave of test_program_new is
constant MAX_VHDL_BFM : integer := 1024;
signal api_if : std_logic_vector (MAX_VHDL_BFM - 1 downto 0);
--Master set and push
procedure master_set_and_push_command (request : in integer;
addr : in std_logic_vector (AV_ADDRESS_W -1 downto 0);
data : in std_logic_vector (AV_DATA_W -1 downto 0);
byte_enable : in std_logic_vector (AV_NUMSYMBOLS -1 downto 0);
idle : in integer;
init_latency : in integer;
signal api_if : inout mm_mstr_vhdl_if_t) is
variable bfm_id : integer := 0;
begin
set_command_request(request, bfm_id, api_if);
set_command_address(addr, bfm_id, api_if);
set_command_byte_enable(byte_enable, INDEX_ZERO, bfm_id, api_if);
set_command_idle(idle, INDEX_ZERO, bfm_id, api_if);
set_command_init_latency(init_latency, bfm_id, api_if);
set_command_burst_count(1, bfm_id, api_if);
set_command_burst_size(1, bfm_id, api_if);
if (request = REQ_WRITE) then
set_command_data(data, INDEX_ZERO, bfm_id, api_if);
push_command(bfm_id, api_if);
end if;
end procedure master_set_and_push_command;
--Master pop and get
procedure master_pop_and_get_response (
request : out integer;
addr : out std_logic_vector (AV_ADDRESS_W -1 downto 0);
data : out std_logic_vector (AV_DATA_W -1 downto 0);
) is
begin
pop_response(bfm_id, api_if);
-- request <= get_response_request(request, bfm_id, api_if);
-- addr <= get_response_address(address, bfm_id, api_if);
-- data <= get_response_data(data, INDEX_ZERO, bfm_id, api_if);
get_response_address(addr, bfm_id, api_if);
end procedure master_pop_and_get_response;
--Avalon write
procedure avalon_write(
addr : in std_logic_vector (AV_ADDRESS_W-1 downto 0);
) is
variable response_request:integer;
variable response_data : std_logic_vector (AV_DATA_W -1 downto 0);
variable response_addr : std_logic_vector (AV_ADDRESS_W -1 downto 0);
begin
master_set_and_push_command(REQ_WRITE,addr,data,"1 111",0,0,api_if);
-- wait until event_all_transactions_complete(bfm_id);
master_pop_and_get_response(response_request, response_addr, response_data, api_if);
if (response_request /= REQ_WRITE) then
report "Failure"
severity failure;
end if;
end procedure avalon_write;
--Checking the value
procedure check_value (
data_value : in std_logic_vector (31 downto 0);
ref_value : in std_logic_vector (31 downto 0)
) is
begin
if (data_value <= ref_value) then
report "PASS";
end if;
end procedure check_value;
--Checking the error
procedure check_error (
signal error : in integer) is
begin
report "error"
severity failure;
end procedure check_error;
--Avalon read
procedure avalon_read(
signal addr : in std_logic_vector (AV_ADDRESS_W-1 downto 0);
signal data : out std_logic_vector (AV_DATA_W -1 downto 0);
) is
begin
master_set_and_push_command(REQ_READ,addr,x"000000 00","1111",0,0,api_if);
-- wait until signal_all_transactions_complete;
master_pop_and_get_response(response_request, response_addr , response_data, api_if );
if response_request /= REQ_READ then
report "Failure"
severity failure;
else
data <= response_data;
end if;
end procedure avalon_read;
begin
process(clk,reset)
begin
if rising_edge(clk) then
avalon_write(ADDR_CASA_DUMMY ,x"00000033", api_if); --SYNC2
avalon_write(ADDR_CASA_DUMMY ,x"00000011", api_if); --DA
avalon_write(ADDR_CASA_DUMMY ,x"00000005", api_if); --COUNT
avalon_write(ADDR_CASA_DUMMY ,x"00000001", api_if); --CMD
avalon_write(ADDR_CASA_DUMMY ,x"00000002", api_if);
avalon_write(ADDR_CASA_DUMMY ,x"00000003", api_if);
avalon_write(ADDR_CASA_DUMMY ,x"00000004", api_if);
avalon_write(ADDR_CASA_DUMMY ,x"000000c1", api_if); --crc1
avalon_write(ADDR_CASA_DUMMY ,x"000000c2", api_if); --crc2
-- avalon_write(ADDR_CASA_DUMMY ,x"00000002", api_if); --wrong
-- avalon_write(ADDR_CASA_DUMMY ,x"00000003", api_if); --wrong
-- avalon_write(ADDR_CASA_DUMMY ,x"00000004", api_if); --wrong
-- avalon_write(ADDR_CASA_DUMMY ,x"000000fc", api_if); --SYNC1 (second packet)
-- avalon_write(ADDR_CASA_DUMMY ,x"00000033", api_if); --SYNC2
-- avalon_write(ADDR_CASA_DUMMY ,x"00000022", api_if); --DA
-- avalon_write(ADDR_CASA_DUMMY ,x"0000000a", api_if); --COUNT 10
-- avalon_write(ADDR_CASA_DUMMY ,x"00000001", api_if); --CMD
-- avalon_write(ADDR_CASA_DUMMY ,x"00000005", api_if);
-- avalon_write(ADDR_CASA_DUMMY ,x"00000006", api_if);
-- avalon_write(ADDR_CASA_DUMMY ,x"00000007", api_if);
-- avalon_write(ADDR_CASA_DUMMY ,x"00000008", api_if);
-- avalon_write(ADDR_CASA_DUMMY ,x"00000009", api_if);
-- avalon_write(ADDR_CASA_DUMMY ,x"000000c1", api_if); --crc1
-- avalon_write(ADDR_CASA_DUMMY ,x"000000c2", api_if); --crc2
-- avalon_write(ADDR_CASA_DUMMY ,x"000000fb", api_if); --SYNC1 (third packet)
-- avalon_write(ADDR_CASA_DUMMY ,x"00000011", api_if); --DA
-- avalon_write(ADDR_CASA_DUMMY ,x"00000005", api_if); --COUNT
end process;
end architecture behave;
The api_if parameter in your avalon_write call is not the same types than the one in the procedure declaration. In the procedure declaration:
procedure avalon_write( addr : in std_logic_vector (AV_ADDRESS_W-1 downto 0); data : in std_logic_vector (AV_DATA_W -1 downto 0); signal api_if : inout mm_mstr_vhdl_if_t )
the api_if signal is of type mm_mstr_vhdl_if_t, but in your test bench you declared the api_if signal as a std_logic_vector:
This api_if signal has declaration of mm_mstr_vhdl_if_t which is below type:
type mm_mstr_vhdl_if_base_t is record
req : std_logic_vector (MM_MSTR_INIT downto 0);
ack : std_logic_vector (MM_MSTR_INIT downto 0);
data_in0 : integer;
data_in1 : integer;
data_in2 : std_logic_vector (MM_MAX_BIT_W - 1 downto 0);
data_out0 : integer;
data_out1 : integer;
data_out2 : std_logic_vector (MM_MAX_BIT_W - 1 downto 0);
events : std_logic_vector (MM_MSTR_EVENT_MIN_COMMAND_QUEUE_SIZE downto 0);
end record;
type mm_mstr_vhdl_if_t is array(MAX_VHDL_BFM - 1 downto 0) of mm_mstr_vhdl_if_base_t;
Can you suggest how to declare that in my test program? Thanks
simply:
signal api_if : mm_mstr_vhdl_if_t ;
Thank you very much.It works
