17255 Discussions
verilog HDL error :constant expression cannot contain a hierarchical identifier
Hello everyone!
I got an error message while synthesizing my code in Quartus Prime, it said:
verilog HDL error : constant expression cannot contain a hierarchical identifier.
The example code is :
interface m_if#( parameter LEFTPARA_BITW, parameter RIGHTPARA_BITW, parameter RESULT_BITW ) ( input bit clk, input wire rst ); logic leftpara; logic rightpara; logic res; modport port(input clk, rst, leftpara, rightpara, output res); endinterface module tb_m( m_if.port p ); localparam tmp_resbitw = p.LEFTPARA_BITW > p.RIGHTPARA_BITW ? p.LEFTPARA_BITW : p.RIGHTPARA_BITW;// synthesizer reports error message like above. wire tmpres = (tmp_resbitw)'(p.leftpara) + (tmp_resbitw)'(p.rightpara); always_comb begin if (p.RESULT_BITW > tmp_resbitw) p.res = (p.RESULT_BITW)'(tmpres);// synthesizer reports error message like above. else p.res = tmpres; end endmodule
For I want to use the parameter in module 'tb_m' which is defined in interface 'm_if', how can I work around it?
This is legal and works in simulation. I suspect it is not yet supported in Quartus Synthesis tools.
I suspect you are writing this from VHDL. But all you have to do is write
module tb_m( m_if.port p ); always_comb begin p.res = {pleftpa + p.rightpa}; endmodule
Putting the addition + inside a concatenation {} makes the intermediate result with of addition self-determined, so its length is MAX(L(leftpa), L(rightpa)). See table 11-21 in the 1800-2012 LRM. There's no need to truncate the intermediate result width if it is larger than the final result. Verilog does that silently for you.
--- Quote Start ---
--- Quote End ---
Hi, Mr.dave_59!
Thank you for replying.
Does Altera provide any way for us to commit these deficiency?
--- Quote Start ---
Hi, Mr.dave_59!
--- Quote End ---
Yes. Open a service request. You'll need an Altera account to do that.
