17257 Discussions
verilog code for counter which counts in both positive and neg ede clock
Anyone please help me write a counter module in verilog in which count should be incremented in both positive edge and negaive edge clock.... please help...
Thank You
Well, you might struggle in an FPGA, as FPGAs can only use either the rising or the falling, not both.
it can be do with some trick;
on slow speed you can select up or down with xored clock source
--- Quote Start ---
--- Quote End ---
That's not exactly true. You can use both positive and negative edges but not to toggle the same register.
I don't do Verilog, but in VHDL it may look like this:
library IEEE; use IEEE.std_logic_1164.all; use IEEE.numeric_std.all; entity posnegcounter is generic( WIDTH_COUNT : natural := 8 ); port( Clk : in std_logic; Reset : in std_logic; Counter : out std_logic_vector(WIDTH_COUNT - 1 downto 0) ); end entity posnegcounter; architecture arch of posnegcounter is signal poscount : unsigned(WIDTH_COUNT - 2 downto 0); -- only need count half signal negcount : unsigned(WIDTH_COUNT - 2 downto 0); begin process(Clk , Reset) begin if (reset = '1') then poscount <= to_unsigned(0, WIDTH_COUNT - 1) ; negcount <= to_unsigned(0, WIDTH_COUNT - 1) ; elsif rising_edge(Clk) then poscount <= poscount + 1; elsif falling_edge(Clk) then negcount <= negcount + 1; end if; end process; counter <= std_logic_vector(poscount + negcount); end arch;
But still I wonder what the purpose might be?
Add two on every positive edge and assume odd when sampled on a negative edge (or v.v.).
Or generate a 2x clock...
At what time would you sample the counter, and using which clock? You could do something like:
reg cnt_q; always_ff @(posedge clk) cnt_q <= cnt_q + 31'd1; reg lsb_q; always_ff @(negede clk) lsb_q <= ~lsb_q; wire counter = {cnt_q, lsb_q};
