17249 Discussions
verilog task passing values
In verilog ,I have doubt while passing different values of one argument to task
eg:-
module sample_ref(input wire clkA, rstA ,SA, output wire d);
initial
begin
repeat(6)
@(posedge clkA)# 1;
operation(rstA,SA);
end
task operation(input wire rst, s);
begin
if(rst)
$display("@%0t test1",$time);
else if(s)
$display("@%0t test2",$time);
end
endtask
endmodule
// here when I try to pass values of variable SA to s inside the task at different times(not at initial time), it didn't enter in to the task. Please explain these..
Without the other code that doesn't work, is impossible to comment on what might be wrong
A task cannot have a wire as an argument
An initial statement cannot have an always block.
--- Quote Start ---
--- Quote End ---
Where is there an always block?
actually I'm verifying(using Verilog) a DUT by using reference model in that I have doubt on pass arguments to the task inside if else statement.
initial
begin
repeat(6)
@(posedge clkA)# 1;
operation(rstA,SA);
end
task operation(input rst, s);
begin
if(rst)
else if(s)
end
endtask
Instead of just repeating your question from the first post - how about showing us some code that exhibits the problems?
I saw one at "always @(posedge clkA)". Or I thought I did, or I'm crazy...
