17268 Discussions
verilog testbench file in emacs verilog mode
The testbench templates created by quartus-II (Processing->Start->Test Bench Template Writer) produce <filename>.vt files. When I try to open them in my emacs text editor, they do not open in verilog mode. Does anyone know if there is a way to:
1.) Change the default extension used by the Test Bench Template Writer to be something like, say, <filename>_tb.v
2.) Force emacs to open a <filename>.vt file in verilog mode
I've been changing the filenames manually, but this requires annoying extra steps every time I create a new test bench.
Thanks!
--- Quote Start ---
--- Quote End ---
You're looking for auto-mode-alist
This article looks fairly short and to the point:
http://jeremy.zawodny.com/emacs/emacs-4.html
It worked! That was perfect, thanks for the link.
