17259 Discussions
vhdl signal delay block code randomly not working
mcorr16
I'm trying to run a signal delay block I coded in VHDL on an Altera MAX II. It works "normally" but sometimes it seems it doesn't apply the delay as expexted. Do you have any idea of what I did wrong?
Michele
LIBRARY IEEE;
USE IEEE.std_logic_1164.ALL;
use IEEE.std_logic_arith.all;
use IEEE.std_logic_unsigned.all;
use IEEE.Numeric_std.all;
ENTITY Delay IS
PORT
input    : IN std_logic;
delayType : IN std_logic;
clk : IN std_logic;
output : OUT std_logic
END Delay;
ARCHITECTURE Delay_signals OF Delay IS
  signal output_status : std_logic;
signal status_counter : std_logic_vector(7 downto 0);
signal counter_thr: std_logic_vector(7 downto 0);
BEGIN
PROCESS (clk, input, delayType, output_status)
BEGIN
IF delayType = '0' THEN
-- GateDelay for external 2 us = 80 ticks
counter_thr <= B"01010000";
ELSE
-- Internal IGBTs delay 3.5 us = 140 ticks
counter_thr <= B"10001100";
END IF;
IF rising_edge(clk) THEN
IF input = '1' THEN
IF output_status = '0' THEN
status_counter <= status_counter + 1;
-- 1 us = 40 ticks
IF status_counter > counter_thr THEN
output_status <= '1';
status_counter <= (others => '0');
END IF;
ELSE
END IF;
ELSE
IF output_status = '1' THEN
output_status <= '0';
END IF;
ELSE
END IF;
END IF;
END IF;
output <= output_status;
END PROCESS;
END Delay_signals;
Vicky1
Have you verified the functionality of your design by writing the testbench?
Please share here simulation screenshot & elaborate your observation.
Vicky
mcorr16
​Hi,
I didn't write the testbench. I'm using the MAX II to route some signals using a main schematic file, .bdf, where I do some AND&OR logics: it's a 10 years old design. I recently tried to add some delays with the code I posted and I noticed that normally the input signal is correctly delayed with the forecasted value: it just randomly cuts the delay at the rise or fall. It seems like my "static variable" output_status sometimes doesn't retain the correct value more than a clock issue because otherwise I would expect to experience some random effects also on the value of the delay applied instead or the delay is right there (most of the times) or it's cut.
Maybe it's worth to say that I'm using this block multiple times in the schematic
thanks for your support.
Michele
Vicky1
Hi Michele,
"Hi,
Vicky" --------- I would like to suggest before implementing any design(HDL or schematic) on board you should verify the functionality of the design writing testbench & tracing the simulation waveforms so if you want to clarify your issue, please provide screenshot of your simulation window.
Vicky
Vicky1
May I know any update or Should I consider that case to be closed?
Vicky
mcorr16
​Hello,
 yes I solved the issue. It was not linked to my VHDL design but to metastability problem
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/wp/wp-01082-quartus-ii-metastability.pdf
Passing all my inputs through a flip-flop solved I the problem.
thanks
regards
Michele
