17255 Discussions
vsim syntax error in wavefront file
Hi.
I'm following a simple example implementing a 4-bit full adder in Quartus II 14.0. When the circuit is ready for functional simulation, I create a wavefront file from the Simulation Wavefront Editor. In order to simplify the process to find the error I only add one of the A input nodes in the wavefront file - 1 single bit. Always forced to low to make it even simpler. I leave the rest of the signals for the moment.
When I run the functional simulation, the following messages are displayed:
**** Generating the ModelSim Testbench ****
quartus_eda --gen_testbench --check_outputs=on --tool=modelsim_oem --format=verilog Prova1 -c Prova1 --vector_source="C:/altera/14.0/Waveform_4bitadder.vwf" --testbench_file="C:/altera/14.0/simulation/qsim/Waveform_4bitadder.vwf.vt"
Completed successfully.
**** Generating the functional simulation netlist ****
quartus_eda --functional=on --flatten_buses=off --simulation --tool=modelsim_oem --format=verilog --output_directory="C:/altera/14.0/simulation/qsim/" Prova1 -c Prova1
**** Generating the ModelSim .do script ****
C:/altera/14.0/simulation/qsim/Prova1.do generated.
**** Running the ModelSim simulation ****
c:/altera/14.0/modelsim_ase/win32aloem//vsim -c -do Prova1.do
Reading C:/altera/14.0/modelsim_ase/tcl/vsim/pref.tcl
# 10.1e
# do Prova1.do
# ** Warning: (vlib-34) Library already exists at "work".
# Model Technology ModelSim ALTERA vlog 10.1e Compiler 2013.06 Jun 12 2013
# -- Compiling module \4bitadder
# Top level modules:
# \4bitadder
# ** Error: Waveform_4bitadder.vwf.vt(30): near "4": syntax error, unexpected INTEGER NUMBER, expecting IDENTIFIER or automatic or TYPE_IDENTIFIER or static
# ** Error: c:/altera/14.0/modelsim_ase/win32aloem/vlog failed.
# Executing ONERROR command at macro ./Prova1.do line 4
Error.
I'm going crazy trying to find the root cause of the error. Can anyone give me a hint on what is going on?
Thanks!
Enric
Problem solved!
The name of my .bdf file started by a number ("4bitadder.bdf"). It seems .bdf files must begin with a letter.
Thanks anyway!
This is because modelsim cannot simulation bdf files, they must be converted to VHDL or Verilog before simulation. In both of these languages identifiers must start with a letter.
