16635 Discussions
what is wrong in this VHDL code?
Hey guys
i have this VHDL code but when i compile it i got an error message thx said: Error (10818): Netlist error at DSS_LUT.vhd(21): can't infer register for Hex_out[8] because it does not hold its value outside the clock edge.
This is the code :
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
entity DDS_LUT is
port
clk : in std_logic;
--encoder_a : in std_logic;
data_b : in integer range 3185 to 4215 ; --std_logic_vector(12 downto 0);
Hex_out : out std_logic_vector (30 downto 0) --(need output with hexa not bin)
end;
architecture arc_DDS_LUT of DDS_LUT is
begin
process (data_b)
begin
if CLK'EVENT and CLK = '1' then
case data_b is
when 3185=> Hex_out <= ("1010101101110111011101110111100");
when 3186=> Hex_out <= ("1010101101101001110100000011011");
when 3187=> Hex_out <= ("1010101101011100001010001111011");
when 3188=> Hex_out <= ("1010101101001110100000011011010");
when 3189=> Hex_out <= ("1010101101000000110110100111010");
when 3190=> Hex_out <= ("1010101100110011001100110011001");
when 3191=> Hex_out <= ("1010101100100101100010111111001");
when 3192=> Hex_out <= ("1010101100010111111001001011001");
when 3193=> Hex_out <= ("1010101100001010001111010111000");
when 3194=> Hex_out <= ("1010101011111100100101100011000");
when 3195=> Hex_out <= ("1010101011101110111011101110111");
when 3196=> Hex_out <= ("1010101011100001010001111010111");
when 3197=> Hex_out <= ("1010101011010011101000000110110");
when 3198=> Hex_out <= ("1010101011000101111110010010110");
when 3199=> Hex_out <= ("1010101010111000010100011110110");
when 3200=> Hex_out <= ("1010101010101010101010101010101");
when 3201=> Hex_out <= ("1010101010011101000000110110101");
when 3202=> Hex_out <= ("1010101010001111010111000010100");
when 3203=> Hex_out <= ("1010101010000001101101001110100");
when 3204=> Hex_out <= ("1010101001110100000011011010011");
when 3205=> Hex_out <= ("1010101001100110011001100110011");
when 3206=> Hex_out <= ("1010101001011000101111110010011");
when 3207=> Hex_out <= ("1010101001001011000101111110010");
when 3208=> Hex_out <= ("1010101000111101011100001010010");
when 3209=> Hex_out <= ("1010101000101111110010010110001");
when 3210=> Hex_out <= ("1010101000100010001000100010001");
when 3211=> Hex_out <= ("1010101000010100011110101110000");
when 3212=> Hex_out <= ("1010101000000110110100111010000");
when 3213=> Hex_out <= ("1010100111111001001011000110000");
when 3214=> Hex_out <= ("1010100111101011100001010001111");
when 3215=> Hex_out <= ("1010100111011101110111011101111");
when others => Hex_out <= ("1111111111111111111111111111111");
end case;
else
Hex_out <=("0000000000000000000000000000000");
end if;
end process;
end arc_DDS_LUT ;
what the code should do is : every time there is a rising edge I will check the input number I got and give an output number from the case statement
You need to add your clock to the sensitivity list. It should be "process (CLK, data_b)" instead of "process (data_b)".
You should also remove the "else" clause after your case since it will clear your outputs anytime there is a change in the signals specified in the sensitivity list that doesn't correspond to a rising edge of clk. In other words if the input data_b changes then your process is evaluated and the outputs will be cleared.
For style look into two alternative coding details:
(a) You can use the "rising_edge" function which is part of the IEEE std logic library.
(b) You can use Hex notation instead of the binary strings.
Do you want only combinational logic or do you want hex_out to be flip-flops? You've combined the constructs for just combinational logic and logic with flops.
If you want just combinational only, drop the CLK references, and drop the "else hex_out <=("0000000000...000");" fragment
If you want logic followed by flops, change the sensitivity list for the process to be CLK, not data_b, AND drop the else hex_out <=("0000000000...000");" fragment.
\c
For sure I'm no expert in VHDL and maybe there are more elegant solutions, but the following should work:
library ieee;
entity DDS_LUT is
port
clk : in std_logic;
end;
signal hex_out_internal : std_logic_vector (30 downto 0);
begin
hex_out <= hex_out_internal;
-- or maybe: Hex_out (30 downto 0) <= Hex_out_internal (30 downto 0);
process (clk
begin
case data_b is
when 3185=> hex_out_internal <= ("1010101101110111011101110111100");
when 3186=> hex_out_internal <= ("1010101101101001110100000011011");
when 3187=> hex_out_internal <= ("1010101101011100001010001111011");
when 3188=> hex_out_internal <= ("1010101101001110100000011011010");
when 3189=> hex_out_internal <= ("1010101101000000110110100111010");
.... and so on
Hope this helped :)
Right: sensitivity list should be changed, too.
You've already gotten some good responses. In case it wasn't already apparent, you are getting that error because of the statement:
else
This makes your code unsynthesizable. What you are telling Quartus II to do is "when there is a clock transition do this, when there is not a clock transition do that."
The problem being, a clock transition is "true" for an infinitesimally short amount of time. So, what you want to tell Quartus II to do is "after a clock transition, do this." You can do that be removing the 'else' statement. You never want an 'else' or 'elsif' with your if (clk'event).
Thanks u all guys
