where is LPM_ROM?
I'm trying to simulate VGA signals, and working with some tutorial I have, they've used LPM_ROM.
Now, I understood I need to implement this by using Mega Wizard of Quartus, but in my Quartus (and I have 2 versions, 7.2, and 9.1 web edition) I can't find this ROM.
I've searched in my Storage tab of the Mega Wizard and in all other tabs, but there's no LPM_ROM anywhere...
Where do I find it?
Roy
--- Quote Start ---
I've searched in my Storage tab of the Mega Wizard and in all other tabs.
--- Quote End ---
Really? It can be easily found in the Memory Compiler tab as "1- and 2-port ROM".
thanks,
but I thought it should be called "LPM_ROM" and not "1- and 2-port ROM"...
Roy
Who said it should? Actually, all internal RAM or ROM variants are finally instantiating an altsyncram block, whatever's there name.
lpm_rom is just a wrapper of altsyncram.
I think (but I may be wrong) that, once uppon a time, there was an LPM_ROM entry in the megawizzard.
The LPM_ROM module can still be instantiated directly in HDL as well, but there's no wizzard for it.
I think you are right - during the work on my project I used several old tutorials that were in the lab - and they also referenced LPM_ROM (which I switched to 2-port-Rom)
Ok, guys, thanks alot.
I guess you're right...
check out this pdf:
http://www.altera.com.cn/literature/ug/ug_lpm_rom.pdf
page 15, it says LPM_ROM inside the MegaWizard,
but as you've stated, apparently it's an oldie.
Thanks again,
great forum that is!
Roy
