I'm trying to simulate VGA signals, and working with some tutorial I have, they've used LPM_ROM. Now, I understood I need to implement this by using Mega Wizard of Quartus, but in my Quartus (and I have 2 versions, 7.2, and 9.1 web edition) I can't find this ROM. I've searched in my Storage tab of the Mega Wizard and in all other tabs, but there's no LPM_ROM anywhere... Where do I find it? Regards, Roy链接已复制
6 回复数
--- Quote Start --- I've searched in my Storage tab of the Mega Wizard and in all other tabs. --- Quote End --- Really? It can be easily found in the Memory Compiler tab as "1- and 2-port ROM".
I think (but I may be wrong) that, once uppon a time, there was an LPM_ROM entry in the megawizzard.
The LPM_ROM module can still be instantiated directly in HDL as well, but there's no wizzard for it.Ok, guys, thanks alot.
I guess you're right... check out this pdf: http://www.altera.com.cn/literature/ug/ug_lpm_rom.pdf page 15, it says LPM_ROM inside the MegaWizard, but as you've stated, apparently it's an oldie. Thanks again, great forum that is! Roy
