17255 Discussions
why add this code will got loop and compile running like stop
signal enableit : STD_LOGIC; signal wholelooptrue : STD_LOGIC = '1'; enableit <= '1'; process(CLOCK_50) VARIABLE last_clk : std_logic := '0'; VARIABLE counter : integer := 0; VARIABLE last_counter : integer := 0; begin while (whilelooptrue = enableit) loop if SW(0) = '1' then enableit <= '1'; if (CLOCK_50 = '0') AND (last_clk = '1') then if (counter = 0) then txdata8 <= preamble; end if; if (counter = 1) then txdata8 <= preamble; end if; if (counter = 2) then txdata8 <= preamble; end if; if (counter = 3) then txdata8 <= preamble; --end end if; if (counter = 4) then txdata8 <= preamble; end if; if (counter = 5) then txdata8 <= preamble; end if; if (counter = 6) then txdata8 <= preamble; end if; if (counter = 7) then txdata8 <= SFD; end if; if (counter = 8) then txdata8 <= dest_mac_addr1; end if; if (counter = 9) then txdata8 <= dest_mac_addr2; end if; if (counter = 10) then txdata8 <= dest_mac_addr3; end if; if (counter = 11) then txdata8 <= dest_mac_addr4; end if; if (counter = 12) then txdata8 <= dest_mac_addr5; end if; if (counter = 13) then txdata8 <= dest_mac_addr6; end if; if (counter = 14) then txdata8 <= src_mac_addr1; end if; if (counter = 15) then txdata8 <= src_mac_addr2; end if; if (counter = 16) then txdata8 <= src_mac_addr3; end if; if (counter = 17) then txdata8 <= src_mac_addr4; end if; if (counter = 18) then txdata8 <= src_mac_addr5; end if; if (counter = 19) then txdata8 <= src_mac_addr6; end if; if (counter = 20) then txdata8 <= wholepacketlength1; end if; if (counter = 21) then txdata8 <= wholepacketlength2; end if; if (counter = 22) then txdata8 <= payload; end if; if (counter = 23) then txdata8 <= emptyhex; end if; if (counter = 24) then txdata8 <= X"10";--CheckSumResult; end if; last_counter := counter; counter := counter + 1; end if; if (CLOCK_50 = '1') AND (last_clk = '0') then if (counter >= 25) then enableit <= '0'; end if; end if; else enableit <= '0'; end if; end loop; last_clk := CLOCK_50; end process;
Probably because in some cases (sw(0) not '1') your while loop is an infinite loop.
This will not synthesize properly, it doesn't represent proper hardware. The process is executed at each clock edge, so you don't need the while loop. Just start your process with a if rising_edge(clock_50) and do everything inside the if block.
--- Quote Start ---
The process is executed at each clock edge.
--- Quote End ---
No. It's no proper synchronous code at all, because there's no edge sensitive event expression.
if rising_edge(clock_50) is good
however i would like to use switch on to start this process
you should read the switch signal value inside the clocked part of your process so that you only start doing something when the switch is pressed.
