17255 Discussions
why my .vhd file is time-limited?
hello,
i am using quartusII 8.1 web edition and i have got licence of it. but i am unable to generate netlist output, the following message appears:
Error: Can't generate netlist output files because the file "D:/Project/sopc_builder/cpu_0.vhd" is an OpenCore Plus time-limited file
how can i solve this problem???
I think your crack file has some problem!
I also had a similiar problem but I did not need SOPC just a level below for my custom code. I set the current design to the lower level and was able to generate the gatelevel netlist for that level of hierarchy.
Hope that helps.
