Someone plz help me......urgent...!!!!!!!
may i know, manual step to make board ALtera DE2 is connected with my pc (i use window 7and Quartus 9.1v). It is because I already connected it using USB bLASTER and the computer have already detect it but when i want to programmer, it said can't access JTAG Chain. For ur info. i have already change it this software compability to window xp........ what should i do.......plz.......Link Copied
QII 9.1 is not supported by Win7. QII10.0 which is going to release soon will support on win7.
I am using Quartus II 9.1 SP2 web edition on Windows 7 and it works fine with DE2-board. So the problem might be somewhere else..
Can you program in AS-mode?- Mark as New
what do you mean?
Actually, I think it's likely that the configuration mode settings on your board are set for AS programming mode and you're attempting to access the JTAG chain. This won't work. You need to read the board documentation (available from Terasic's website...if you don't have it) to determine if this is the case.
