window 10 Quarters error
choiseokyoung
Hi, I was going to make SR clasp for my college assignment.
Why does this error occur? I want to find a solution to this with me.
I attach the picture and the error
Determining the location of the ModelSim executable...
Using: c:/altera/13.1/modelsim_ase/win32aloem/
To specify a ModelSim executable directory, select: Tools -> Options -> EDA Tool Options
Note: if both ModelSim-Altera and ModelSim executables are available, ModelSim-Altera will be used.
**** Generating the ModelSim Testbench ****
quartus_eda --gen_testbench --check_outputs=on --tool=modelsim_oem --format=verilog latch_s -c latch_s --vector_source=C:/altera/13.1/tukorea_1/Waveform.vwf --testbench_file=C:/altera/13.1/tukorea_1/simulation/qsim/Waveform.vwf.vt
Info: *******************************************************************
Info: Running Quartus II 64-Bit EDA Netlist Writer
Info: Version 13.1.0 Build 162 10/23/2013 SJ Web Edition
Info: Copyright (C) 1991-2013 Altera Corporation. All rights reserved.
Info: Your use of Altera Corporation's design tools, logic functions
Info: and other software and tools, and its AMPP partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Altera Program License
Info: Subscription Agreement, Altera MegaCore Function License
Info: Agreement, or other applicable license agreement, including,
Info: without limitation, that your use is for the sole purpose of
Info: programming logic devices manufactured by Altera and sold by
Info: Altera or its authorized distributors. Please refer to the
Info: applicable agreement for further details.
Info: Processing started: Mon May 06 20:53:38 2024
Info: Command: quartus_eda --gen_testbench --check_outputs=on --tool=modelsim_oem --format=verilog latch_s -c latch_s --vector_source=C:/altera/13.1/tukorea_1/Waveform.vwf --testbench_file=C:/altera/13.1/tukorea_1/simulation/qsim/Waveform.vwf.vt
Info (201000): Generated Verilog Test Bench File C:/altera/13.1/tukorea_1/simulation/qsim/Waveform.vwf.vt for simulation
Info: Quartus II 64-Bit EDA Netlist Writer was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 4604 megabytes
Info: Processing ended: Mon May 06 20:53:39 2024
Info: Elapsed time: 00:00:01
Info: Total CPU time (on all processors): 00:00:01
Completed successfully.
**** Generating the functional simulation netlist ****
quartus_eda --functional=on --flatten_buses=off --simulation --tool=modelsim_oem --format=verilog --output_directory=C:/altera/13.1/tukorea_1/simulation/qsim/ latch_s -c latch_s
Info: Processing started: Mon May 06 20:53:40 2024
Info: Command: quartus_eda --functional=on --flatten_buses=off --simulation=on --tool=modelsim_oem --format=verilog --output_directory=C:/altera/13.1/tukorea_1/simulation/qsim/ latch_s -c latch_s
Info (204019): Generated file latch_s.vo in folder "C:/altera/13.1/tukorea_1/simulation/qsim//" for EDA simulation tool
Info: Processing ended: Mon May 06 20:53:41 2024
**** Generating the ModelSim .do script ****
C:/altera/13.1/tukorea_1/simulation/qsim/latch_s.do generated.
**** Running the ModelSim simulation ****
c:/altera/13.1/modelsim_ase/win32aloem//vsim -c -do latch_s.do
Reading C:/altera/13.1/modelsim_ase/tcl/vsim/pref.tcl
# 10.1d
# do latch_s.do
# ** Warning: (vlib-34) Library already exists at "work".
# Model Technology ModelSim ALTERA vlog 10.1d Compiler 2012.11 Nov 2 2012
# -- Compiling module latch_s
# Top level modules:
# latch_s
# -- Compiling module latch_s_vlg_sample_tst
# -- Compiling module latch_s_vlg_check_tst
# ** Error: Waveform.vwf.vt(60): near "/": syntax error, unexpected '/', expecting ')'
# ** Error: c:/altera/13.1/modelsim_ase/win32aloem/vlog failed.
# Executing ONERROR command at macro ./latch_s.do line 4
Error: can't read "FileWatch(fileName)": no such element in array
Error.
sstrell
Without seeing the files mentioned in the errors, there's no way for anybody to figure this out.
Also, you are using an 11 year old version of Quartus.  Can you try a newer version?
ShengN_Intel
Create a new vwf and save that vwf to the default location. Does the problem still persist?
Sheng
ShengN_Intel
Do you have any further update? Does the problem being resolved?
Sheng
