17268 Discussions
writing and reading the same pipe in one kernel
Hi
I want to write and read the same pipe in one kernel like this:
channel float c0 __attribute__((depth(2)));
__kernel void testkernel() {
for(int i = 0; i < n; i ++){
page_ranks = read_channel_intel(c0); //read from the channel
//do some computation of the page_rank and generage new_rank
write_channel_intel(c0, new_rank); //write new_rank to this pipe
and this kernel is being run in multiple iterations, each time it will read from last iteration's result and compute new rank and use the new rank as the new input for the next iteration.
When I compile this, I get the error of "Compiler Error: Multiple writes to channel c0", this is the only line I got in the log.
Any suggestions on how to deal with this case using pipe or how to resolve this bug?
Are you unrolling your loops? Post your complete kernel since the snippet you have posted should compile correctly.
--- Quote Start ---
--- Quote End ---
Below is my kernel code:
# define M 100
__kernel void mapreduce_page_rank(__global float* restrict page_ranks,
int n,
const __global int* restrict pages,
const __global unsigned int* restrict noutlinks){
int i, j, t;
float new_rank;
float d_factor = 0.85;
float cur;
float maps;
float outbound_rank;
float new_rank_copies[M];
# pragma unroll
for (i = 0; i < M; i ++){
new_rank_copies = 0;
for(i=0; i<n; ++i){
new_rank = 0.0;
for(j=0; j<n; ++j){
outbound_rank = page_ranks[j] / (double)noutlinks[j];
maps = pages[i*n+j] * outbound_rank;
cur = new_rank_copies[m-1] + maps;
# pragma unroll
for(int c = m-1; c > 0; c--){
new_rank_copies[c] = new_rank_copies[c - 1];
new_rank_copies[0] = cur;
# pragma unroll
for(int j = 0; j < m; j ++){
new_rank += new_rank_copies[j];
new_rank_copies[j] = 0;
new_rank = ((1-d_factor)/n)+(d_factor*new_rank);
write_channel_altera(c0, new_rank);
__kernel void produce_page_rank(__global float* restrict page_ranks,
int n,
int i, j, t;
float new_rank;
float cur;
float maps;
float new_rank_copies[m];
# pragma unroll
for (i = 0; i < m; i ++){
page_ranks[i] = read_channel_altera(c0);
for(i=0; i<n; ++i){
new_rank = 0.0;
for(j=0; j<n; ++j){
cur = new_rank_copies[M-1] + maps;
# pragma unroll
for(int c = M-1; c > 0; c--){
# pragma unroll
for(int j = 0; j < M; j ++){
Well, you are clearly writing to the same channel twice, once in your first kernel and the second time in your second kernel. This is not allowed since each channel works as a FIFO with one read point and one write point. However, I think the newer versions of the compiler (v17 or v17.1) allow multiple channel call sites but I haven't tried it myself.
