17268 Discussions
Good editor for OpenCL in linux (.cl files)
I have tried installing the opencl extensions for visual code and eclipse. They do not work. Any suggestions from your side?
What do you mean they do not work? I use the VS Code OpenCL plugin and it highlights the syntax just fine.
I have tried using the editor you have mentioned. I have enabled the plugin. I dont see the kernel code highlighted. I have attached VS code window. I am currently using linux.
I cannot real see what extension that is because of the low resolution image, but this is the one I installed: https://marketplace.visualstudio.com/items?itemname=galarius.vscode-opencl
Don't forget to reload your VS Code client after installation. I have VS Code 1.23.0 btw. And the plugin version 0.2.1
