573 Discussions
Accessing the Global Timer from the FPGA (Cyclone V SoC)?
Rink
Is it possible for the FPGA logic side to access the Global Timer?
Does it involve a memory-access via the FPGA–to–HPS bridge perhaps?
I am interested in capturing the value to resolve event timing across the FPGA and HPS boundaries?
Thanks!
FawazJ_Altera
Are you trying to access a register from HPS?
You can access any register in HPS by FPGA master through f2h bridge.
If you are trying to access a memory location, say for example your HPS will write a data to memory location, you can access this location by FPGA master through f2sdram bridge.
