573 Discussions
Arria10 SOCFPGA ARM DMA usage - way to use ARM DMA to copy bulk data inside DDR ?
JET60200
I am using A10 SOCFPGA , where Linux runs on SOC ARM(dual-A9).
In my application, there‘re bulks of memory copying from one place to another place each 1ms,currently I use memcpy() which occupy CPU heavily.
Thus I want to use ARM DMA to do this, to avoid use cpu memcpy() . The question is " HOW _TO DO THIS " ? is there any code example ?
Thanks for help
EBERLAZARE_I_Intel
You may find design example in our design store, unfortunately there is no exact design example that you are requesting.
https://fpgacloud.intel.com/devstore/platform/?search=dma&acds_version=any&family=arria-10
However, there is a Data Mover which utilize the msGDMA, that uses the ARM Cortex A9, you may check it out here:
https://rocketboards.org/foswiki/Projects/DatamoverCopy
EBERLAZARE_I_Intel
Any follow up from your side?
JET60200
Hi el,
In RocketBoards, I was told here is an very similar example code ( https://github.com/robertofem/CycloneVSoC-examples/tree/master/Linux-modules/DMA_PL330_LKM_basic ),
Thus I'm trying to check this example and update to my A10SOC LINUX.
EBERLAZARE_I_Intel
Got it, I also recommend that you check the datamover example to help guide you.
