573 Discussions
Can anyone verify for me the following code for 32-bit calculator in verilog using FSM? 4 operation- +,-,*,/ Works on DVS protocol
Dave7
module calc (
         input [7:0] inpA ,
         input [7:0] inpB ,
         input [01:0] inpOpType ,
         output[15:0] outC ,
         input    iValid ,
         output    iStall ,
         input    oStall ,
         output    oValid ,
         input    clk ,
         input    rstn
  parameter  ST_IDL  = 1'b0 ;
  parameter  ST_STALL = 1'b1 ;
  reg     inp_dstall_r, oup_dval_r, lat_inp_r ;
  reg     inp_dstall_s, oup_dval_s, lat_inp_s ;
  reg     st_cur, st_nxt ;
  reg [31:0] store_a, store_b, oup_s ;
  reg [01:0] store_ctrl ;
// FSM
parameter s0 = 2'b00, s1 = 2'b01, s2 = 2'b10, s3 = 2'b11;
reg [1:0] cs, ns;
always @ (posedge clk)
begin
 if(rstn)
    cs <= s0;
 else
    cs <= ns;
end
always @(posedge clk or negedge rstn) begin
 if(!rstn) begin
  lat_inp_r  <= 1'b0 ;
  inp_dstall_r <= 1'b0 ;
  st_cur    <= ST_IDL ;
  oup_dval_r  <= 1'b0 ;
 end
 else begin
  inp_dstall_r <= inp_dstall_s ;
  lat_inp_r  <= lat_inp_s ;
  st_cur    <= st_nxt ;
  oup_dval_r  <= oup_dval_s ;
 end
end
  ns = s0;
  case (cs)
    s0 : if (!store_ctrl) ns = s1;
    s1 : if (store_ctrl) ns = s2;
      else ns = s1;
    s2 : if (store_ctrl) ns = s3;
      else ns = s1;
    s3 : if (!store_ctrl) ns = s1;
  endcase
end
always @(posedge clk) begin
 if(lat_inp_s) begin
  store_a  <= inpA ;
  store_b  <= inpB ;
  store_ctrl <= inpOpType ;
 end
end
always @* begin
 if(store_ctrl == 2'b00) oup_s = store_a + store_b ;
 else if(store_ctrl == 2'b01) oup_s = store_a - store_b ;
 else if(store_ctrl == 2'b10) oup_s = store_a * store_b ;
 else if(store_b == 0) oup_s = 0 ;
 else oup_s = store_a / store_b ;
end
assign iStall  = inp_dstall_r ;
assign oValid  = oup_dval_r ;
assign outC   = oup_s ;
endmodule
Vicky1
Hi Dhaivat,
People in Intel community are not going to write code for you, but they will help you to understand or resolve the issue you are having. . .
Please refer the below steps & try to create testbench with appropriate test inputs & verify the design using simulation waveforms
1. First create testbench & instantiate the design in it & eventually compile the testbench in simulation tool(ModelSim) as shown in below link,
https://www.youtube.com/watch?v=o2KDwNN5-yw
2. Another way : Go to 'Processing' -> 'Start' -> 'Start Test Bench Template Writer'
Check'Message window' for .vt or .vht file generated in projet directory
3. For NativeLink Simulation use testbench generated in either step(1) or step(2) & try to simulate as shown in below link,
https://www.youtube.com/watch?v=PmVVXQchv2c
4. One more way to simulate design using vector waveform files refer the link below,
https://www.youtube.com/watch?v=e_ksjHd6sY0
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Best Regards
Vikas
