DE-10 PROJECT
aiedb
HII i bought the DE-10 KIT
AND I WANT TO USE THE UART ON THE HPS SIDE TO RECIEVE A CHAR FROM THE PC
according to the char value to turn on a gpio on the fpga fabric side
that means that i there is have to be hps_to_fpga bride involved
is there an example that i can use or an application or a tutorial that can help me in this subject
aikeu
Hi aiedb,
I think we dont have the complete example for your particular request.
I will provide a brief idea on how I think the system can work.
First thing is to have your system to boot up from Uboot and if required, to Linux kernel(can consider if required to run an application code using linux for your project ). Then make sure from there you can observed any logs through UART on the terminal(example using putty in windows ) on your PC. If you can observe the UART logs, you will be able to perform inputs from the terminal on your PC.
You will have your FPGA design generated using Quartus which consider the bridge to control the register data used for the gpio on FPGA side.
During Uboot boot up to Uboot user interface. Flash in your FPGA design(.sof file) and then execute "bridge enable" command.
After that, Use "mw" command to write your data to the specific address which control the gpio in your design.
Reference link which may help:
https://www.rocketboards.org/foswiki/Documentation/BuildingBootloaderCycloneVAndArria10
https://www.terasic.com.tw/wiki/index.php?title=DE10_Advance_Running_Linux_via_UART_Terminal:_Setting_Up_UART_Terminal&oldid=2880
https://www.terasic.com.tw/wiki/DE10_Advance_revC_demo:_Develop_the_C_Code
Aik Eu
aiedb
hii thanks for your reply , i will try to look in the links you gave me
aikeu
Hi aiedb,
I will close the thread if no further question.
Aik Eu
aikeu
Hi aiedb,
I will close the thread for now. Do consider to open a new thread if got further question.
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
Aik Eu
