Comunicados
573 Discussões
Executing a application/executable file on customized boot image for DE1SOC board
snehal_p
Novo colaborador I
16.478 Visualizações
I'm trying to execute a simple led switch application on customized boot image.
PFA screenshot of the error received.
Can anyone help me diagnose what the issue is?
snehal_p
1 Solução
JingyangTeh_Altera
Funcionário
14.984 Visualizações
Hi
I have tried out your zImage and able to run the led application successfully.
Please find the screenshot below:
Did you flash the FPGA configuration before booting into the linux environment?
As for the fitter error, you will need to run both of the TCL script below (located:soc_system\synthesis\submodules):
hps_sdram_p0_parameters.tcl
hps_sdram_p0_pin_assignments.tcl
Jingyang, Teh
Ver solução na publicação original
54 Respostas
JingyangTeh_Altera
Funcionário
5.268 Visualizações
Hi Snehal_p
The command I shared the first time is the wrong address, it got an additional zero.
Could you try it one more time? The address of the LED bank should be 0xff210008 instead of 0xFF2010008.
Let me try out your version of zImage and get back to you.
Jingyang, Teh
snehal_p
Novo colaborador I
5.256 Visualizações
Hello Jingyang,
Yes, let me try with devmem
I came across the palce and route error, can you please help me with this.
PFA error message.
snehal_p
Novo colaborador I
5.256 Visualizações
hello,
PFA error message
thanks,
snehal_p
JingyangTeh_Altera
Funcionário
14.985 Visualizações
Hi
Jingyang, Teh
snehal_p
Novo colaborador I
5.246 Visualizações
Hello Jingyang,
Thanks for the prompt support, fitter error solved.
Let me test with my zImage, actually problem occurs while executing the application file
Can you try executing hps led hex demostration using my zImage
snehal_p
JingyangTeh_Altera
Funcionário
5.226 Visualizações
Hi snehal_p
Sorry for the late reply.
Yes I did tried running the led hex demonstration on your zImage and it was successfull.
Maybe you could try sending me your copy of the led hex demonstration binary? and I will try it out on my board here.
Jingyang, Teh
snehal_p
Novo colaborador I
5.213 Visualizações
Hello Jingyang,
PFA  binary file.
Could this be OS of my system
I'm using Ubuntu 20.04.4 LTS
snehal_p
JingyangTeh_Altera
Funcionário
5.203 Visualizações
Hi Snehal_p
I tried running your application and zImage, there are able to run without crashing.
However I notice that the application is not able to bling the led on the board.
You are working on a DE1SOC or DE0-Nano-Soc?
The link that you shared is using a DE0-Nano-Soc.
Could you share me the source of your application and your quartus image?
To check if you are accessing the correct memory address for the led.
Jingyang, Teh
snehal_p
Novo colaborador I
5.196 Visualizações
snehal_p
Novo colaborador I
5.182 Visualizações
Hello Jingyang,
I'm still facing issues launching DS5 can you PFA screenshot to analyze what the issue is
snehal_p
JingyangTeh_Altera
Funcionário
5.167 Visualizações
Hi Snehal
Could try following the installation steps for SOCED in the link below:
https://www.rocketboards.org/foswiki/Documentation/SoCEDS#Install_SoC_EDS
You could refer to the linux steps under "Linux Installation".
Jingyang, Teh
JingyangTeh_Altera
Funcionário
5.159 Visualizações
Hi Snehal
Are you still facing problem with launching DS?
Jingyang, Teh
snehal_p
Novo colaborador I
5.150 Visualizações
Hello Jingyang,
Yes, I'm sill facing issues with launching DS5.
snehal_p
JingyangTeh_Altera
Funcionário
5.137 Visualizações
Hi Snehal
Did you went through the installation for SoCED in the link below?
Jingyang, Teh
snehal_p
Novo colaborador I
5.086 Visualizações
Hello Jingyang,
Yes, I followed the steps in the document.
snehal_p
JingyangTeh_Altera
Funcionário
5.028 Visualizações
Hi Snehal
Happy New Year!
That is weird.
Could you try to print out the environmental variable " SOCEDS_DEST_ROOT"?
Jingyang, Teh
snehal_p
Novo colaborador I
4.992 Visualizações
Hello Jingyang,
Thank you!
Happy New Year!
PFA screenshot.
snehal_p
snehal_p
Novo colaborador I
4.980 Visualizações
Hello Jingyang,
I'm facing issues with the booting process.
zImage and rootfs I'm using are readily available from rocketsboard link.
PFA screenshots one with zImage for 3.10ltsi receiving garbage value after starting kernel and for original terasic console it is getting stuck after starting kernel
snehal_p
JingyangTeh_Altera
Funcionário
4.963 Visualizações
Hi Snehal
Could you try upgrading your version of Quartus? I see that your quartus version is quite old, the latest version now is 22.1.
Which version of rootfs you are using? Could you try using the rootfs from the GSRD as well?
Jingyang, Teh
snehal_p
Novo colaborador I
4.954 Visualizações
Hello Jingyang,
I'm using the readily available images
  • zImage is present in location “SDCard_Booting/CycloneVSoC-examples-master/SD-operating-system/Angstrom-v2013.12/Files_to_build_SD_DE1-SoC/zImages/Original Terasic Console/zImage”
  • Root File System is present in location “SDCard_Booting/CycloneVSoC-examples-master/SD-operating-system/Angstrom-v2013.12/Files_to_build_SD_DE1-SoC/Angstrom-console-rootfs.tar.gz”
sneahl_p
snehal_p
Novo colaborador I
4.942 Visualizações
Hello Jingyang,
I'm trying to generate rootf using steps https://www.rocketboards.org/foswiki/Documentation/EmbeddedLinuxBeginnerSGuide
Getting the error pfa screenshot.
Can you please help me with this.
snehal_p
Responder
