Comunicados
573 Discussões
Executing a application/executable file on customized boot image for DE1SOC board
snehal_p
Novo colaborador I
16.378 Visualizações
I'm trying to execute a simple led switch application on customized boot image.
PFA screenshot of the error received.
Can anyone help me diagnose what the issue is?
snehal_p
1 Solução
JingyangTeh_Altera
Funcionário
14.884 Visualizações
Hi
I have tried out your zImage and able to run the led application successfully.
Please find the screenshot below:
Did you flash the FPGA configuration before booting into the linux environment?
As for the fitter error, you will need to run both of the TCL script below (located:soc_system\synthesis\submodules):
hps_sdram_p0_parameters.tcl
hps_sdram_p0_pin_assignments.tcl
Jingyang, Teh
Ver solução na publicação original
54 Respostas
JingyangTeh_Altera
Funcionário
4.202 Visualizações
Hi Snehal_p
For the SD Card Image could you try out the sd card image from the link below:
https://releases.rocketboards.org/2022.11/gsrd/c5_gsrd/
As for the compilation error, could you try checking the GNU version with the command "ldd --version".
Could you try upgrading the GNU version if it is below 1.4.19.
Jingyang, Teh
JingyangTeh_Altera
Funcionário
4.189 Visualizações
Hi
Any update on this case?
Jingyang, Teh
snehal_p
Novo colaborador I
4.175 Visualizações
Hi Jingyang,
PFA error screenshot while compiling c program. Can you please help me with the library files for rtcds3231 and i2c, also the steps to use .h files
snehal_p
snehal_p
Novo colaborador I
4.175 Visualizações
Hi Jingyang,
PFA error screenshot while compiling c program. Can you please help me with the library files for rtcds3231 and i2c, also the steps to use .h files. I ge similar error when I try to compile demonstration code for gsensor.
snehal_p
JingyangTeh_Altera
Funcionário
4.161 Visualizações
Hi Snehal
Could you try adding the following parameter into your make file to solve the define error:
ALT_DEVICE_FAMILY = soc_cv_av
As for the library error could you use the directory path below:
C:/intelFPGA/18.1/embedded/ip/altera/hps/altera_hps/hwlib/include
We will use the directory a folder up.
Jingyang, Teh
snehal_p
Novo colaborador I
4.155 Visualizações
Hello Jingyang,
PFA screenshot of error I'm getting after making changes to the path.
snehal_p
JingyangTeh_Altera
Funcionário
4.147 Visualizações
Hi Snehal_p
Could you share me the git repo that you got the library for the rtcds3231 ?
Also please share me the make file that you are using to build the library?
Jingyang, Teh
snehal_p
Novo colaborador I
4.129 Visualizações
Hi Jingyang,
PFA details.
https://github.com/contiki-os/contiki
snehal_p
snehal_p
Novo colaborador I
4.129 Visualizações
Hi Jingyang,
PFA details.
snehal_p
JingyangTeh_Altera
Funcionário
4.065 Visualizações
Hi Snehal_p
Could you give me more time to look into this issue?
Since that the library is an Arduino base, I need to see if we could compile it to properly.
Jingyang, Teh
snehal_p
Novo colaborador I
4.058 Visualizações
Hi Jingyang,
The application file is getting compiled by adding main() to the c code for rtc ds3231.
but it is giving controller timed out PFA screenshot of the error.
snehal_p
JingyangTeh_Altera
Funcionário
4.024 Visualizações
Hi Snehal
Could we follow up the i2c issue on the new forum that you created?
https://community.intel.com/t5/FPGA-SoC-And-CPLD-Boards-And/interfacing-RTC-module-to-hps-driven-i2c-pins/m-p/1449952#M23958
Since that the original issue that was created for this case have been resolved.
Is it ok if we close this case?
Jingyang, Teh
JingyangTeh_Altera
Funcionário
3.990 Visualizações
Hi
Since this thread been resolve, I shall set this thread to close pending. If you still need further assistance, you are welcome reopen this thread within 20days or open a new thread, some one will be right with you. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 10 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Jingyang, Teh
Responder
