HPS Clock Frequency
서박사
新貢獻者 I
1,491 檢視
I'm wondering if the clock frequency of the HPS (@DE1-SoC, ARM Coretex A9) is reconfigurable.
That is, is there any way to change the clock frequency of the processor?
(As I know, it is fixed to 800MHz @DE1-SoC)
0 積分
1 解決方案
aikeu
員工
1,466 檢視
Hi 서박사,
  1. Open the output clocks page of the HPS IP parameter editor in Qsys.
  2. Un-tick the use default MPU clock setting
  3. Manually set the MPU clock rate in the MPU Clock box
  4. Re-generate the Qsys system
  5. Re-compile the Quartus Prime project
  6. Generate a new Pre-loader using BSP-Editor
Aik Eu
在原始文章中檢視解決方案
6 回應
aikeu
員工
1,480 檢視
Hi 서박사,
I will get back to you once I have the info for your quesions.
Aik Eu
서박사
新貢獻者 I
1,477 檢視
Thank you for the answer. I'll be waiting for the additional information.
aikeu
員工
1,467 檢視
Hi 서박사,
Aik Eu
서박사
新貢獻者 I
1,417 檢視
Sorry for the late response.
I'll try to change the clock frequency through the method you suggested.
Thank you for your effort and time for the solution!
aikeu
員工
1,453 檢視
Hi 서박사,
I will close this thread if no further questions from you.
Aik Eu
aikeu
員工
1,440 檢視
Hi 서박사,
I am closing the thread for now, do raise another thread if there is further question.
Aik Eu
回覆
