573 Discussions
Having problem in writing to the EPCQ-L512 sectors follow by sectors erase
SLoi0
I am having problem in writing to the EPCQ-L512 sectors follow by sectors erase.  I was able to write follow by bulk erase but not sectors erase. Writing to sectors follow by sectors erase worked in EPCQ-512 but not in EPCQ-L512.
ShafiqY_Intel
Hi SLoi0,
May I know which IP your are using?
SLoi0
I am using Serial Flash Loader IP in Arria 10 Soc. Thanks,
ShafiqY_Intel
Hi SLoI0,
I'm apologize for late reply. Somehow, I didn't get your reply notification.
Have you able to solve this issue?
SLoi0
Yes, I was able to get it to work after I used the "Flag Status Register[7]" instead of "Status Register[0] as an erase/write completion indicator"
Status Register[0] (05h) - One of the following operation is in progress:
  • Write Status Register
  • Write NVCR
  • Write Bytes
  • Erase
Flag Status Register[7] (70h) - Indicates whether one of the following operation is in progress:
  • Write NVCR
  • Write Bytes
  • Erase
What is the different between the two ?
