569 Discussions
Hello, I am working with the My_First_HPS tutorial for the DE10-nano but am unable to open the Embedded_Command_Shell batch file.
ELEIS
I have administrative privileges on my machine but when i run the batch file, the cmd window comes up and then closes immediately... Does anyone have any insight on what could be causing this issue?
Thank you.
Ahmed_H_Intel1
which version you are using? the host is windows or Linux?
Do you see any errors?
ELEIS
Intel FPGA 19.1 working in windows
Ahmed_H_Intel1
I apologize for any inconvenience, Please try grab permission to the installation folder after you install it. the following steps show you how to do it.
Right click the folder>>Properties>>Security Tab>>Select "Authenticated Users">>Press Edit>> Check the "Full control" box>> OK)
Please let me know the result and If this still doesn't fix the error please try another version and avoid 19.1 and 19.2
