572 Discussions
Hi, I am trying to write a simple ISR for handling button presses. I am trying to print "Interrupt!" on every interrupt on the falling edge of a press. The following code is printing nothing:
Shubham_P_Intel
I have configured the PIO module by checking the Synchronously Capture, Enable bit clearing for edge-capture register and Generate IRQ options. IRQ type is set to EDGE, and EDGE type is set to falling.
Following is my code:
#include <stdio.h>
#include "system.h"
#include "altera_avalon_pio_regs.h"
#include "sys/alt_irq.h"
volatile int edge_capture;
/* button IRQ function */
//static void handle_button_interrupts(void* context, alt_u32 id)
static void handle_button_interrupts(void* context)
  /* Cast context to edge_capture's type. It is important that this be
   * declared volatile to avoid unwanted compiler optimization.
  //int delay;
  volatile int* edge_capture_ptr = (volatile int*) context;
  /* Store the value in the Button's edge capture register in *context. */
  *edge_capture_ptr = IORD_ALTERA_AVALON_PIO_EDGE_CAP(BUTTON_BASE);
  /* Reset the Button's edge capture register. */
  IOWR_ALTERA_AVALON_PIO_EDGE_CAP(BUTTON_BASE, 0x0);
// Delay before exiting ISR.
/* Initialize the button_pio. */
static void init_button_pio()
  /* Recast the edge_capture pointer to match the alt_irq_register() function
   * prototype. */
  void* edge_capture_ptr = (void*) &edge_capture;
  /* Enable all 4 button interrupts. */
  IOWR_ALTERA_AVALON_PIO_IRQ_MASK(BUTTON_BASE, 0x1);
  /* Reset the edge capture register. */
  /* Register the interrupt handler. */
  alt_ic_isr_register(BUTTON_IRQ_INTERRUPT_CONTROLLER_ID, BUTTON_IRQ, handle_button_interrupts, edge_capture_ptr, 0x0);
static void handle_button_press(alt_u8 type)
  /* Button press actions while counting. */
  if (type == 'r')
   printf("Interrupt!\n");
int main()
  //IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 0xf);
printf("Init\n");
init_button_pio();
  while (1)
    if(edge_capture!=0)
      handle_button_press('r');
    //for(int i=0;i<1000000;i++){}
  return 0;
Any help/guidance will be greatly appreciated, thanks a lot!
EBERLAZARE_I_Intel
May I know which Quartus Version you are working on? Also which device are you targeting, Cyclone V SoC, Arria 10 SoC etc.
