567 Discussions
Installing Linaro Bare Metal Toolchain under Windows
Stanley_Sun
I deployed the FPGA test environment on Windows10 based on the Intel SoC FPGA Embedded Development Suite (SoC EDS) User Guide,.However, I encountered a problem when installing Linaro Bare Metal Toolchain. I executed the install_linaro.sh script but it failed. The following compile error has occurred.1627292564(1).pngAny feedback or suggestions are welcome.
EricMunYew_C_Intel
May I know which Quartus version you are using?
EricMunYew_C_Intel
Have you disabled your Firewall?
EricMunYew_C_Intel
Campbell
I faced a similar error while trying to install Linaro on Windows.  You could try the fix given here: https://github.com/altera-opensource/intel-socfpga-hwlib/issues/1
Just remember to delete any files that were installed by the script before trying again (i.e. everything except install_linaro.sh if I remember correctly).  You can change the line endings by running "$ git config --global core.autocrlf input" in the Msys terminal
https://stackoverflow.com/questions/10418975/how-to-change-line-ending-settings
