Qspi flash
Anu_Jayan
I would like to flash my board(cyclone 10gx neos 2) through QSPI for that i required example source code. If anyone is having QSPI source code kindly share it with me.
Aj
JingyangTeh_Altera
Hi AJ
For flashing of NIOSII, you could take a look at the example here:
https://www.intel.com/content/www/us/en/docs/programmable/683104/current/nios-ii-processor-booting-from-altera.html
In the example there is an option of loading the application from Flash in placed or copied to the RAM.
Please have a look to see if it is the example you are looking for.
Jingyang, Teh
JingyangTeh_Altera
Hi AJ
Do you have any new update on this case?
Jingyang, Teh
JingyangTeh_Altera
Hi
Since there are no feedback for this thread, I shall set this thread to close pending. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 10 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Jingyang, Teh
