573 Discussions
Quartus in Docker 18.0 standart uboot qeneration does not work
Wild
I try to get quartus run inside docker. I've got everything working but:
  • Uboot generation
  • HDL generation fails at altera_pll (Platform designer)
If i ran the uboot generation according to: https://rocketboards.org/foswiki/Documentation/PreloaderUbootCustomization131
The generation exited without any error but when i try to boot it runs until:
"Hit any key to stop autoboot:"
after that it exits the boot proccess with "Unknown command 'run' ".
We have the quartus environment installed on a Oracle VM where u-boot.img can be generatet bootable. When i generate uboot on docker uboot has size 232.16 kB on VM  232.68 kB .
Does anyone have an idea what could be the cause oft this?
My System ubuntu-trusty in docker (wsl 2, windows host):
i run Quartus 18.0 standart with socEDS (18.0 build 614).
my dockerfile in in the attachment.
Isaac_V_Intel
The version that you are using is 13.1, we did not support that version anymore, could you please refer to the next link, this is the updated version and follow all the steps please.
https://rocketboards.org/foswiki/Documentation/BuildingBootloader
Isaac Vazquez.
