573 Discussions
Does U-boot socfpga_v2019.04 really support LPDDR2?
tlang15
I cannot build cyclone V SPL using LPDDR2 with EDS 19.1.
Longer version:
I have a custom cyclone V board with LPDDR2 HPS memory and so far
I've been using SPL based on U-boot branch socfpga_v2013.01.01.
According to:
 https://rocketboards.org/foswiki/Documentation/BuildingBootloader#Cyclone_V_SoC_45_Boot_from_SD_Card
it seems that I have to upgrade U-boot to socfpga_v2019.04 when using EDS 19.1
but SPL does not compile when using LPDDR2 HPS memory due to missing defines.
The missing ones all seem to be related to DDR3 (e.g. RW_MGR_MRS1).
I tried building new projects containing nothing but a HPS block:
When using default SDRAM (DDR3), SPL builds fine. The defines my build was
missing all exist in hps_isw_handoff/*/sequencer_auto.h
When using Micron LPDDR2 SDRAM, SPL does not build due to missing defines.
hps_isw_handoff/*/sequencer_auto.h does not contain the missing defines.
See build log below.
Looking at code in u-boot-socfpga/drivers/ddr/altera I find no evidence
of LPDDR2 support, e.g. LPDDRDIS is hardcoded to '1' in sequencer.c
So it seems that socfpga_v2019.04 does not support LPDDR2?
/Thomas
k7:~/altera/pl/c5_test_lpddr2/software/bootloader/u-boot-socfpga$ make -j8
 CHK   include/config/uboot.release
 CHK   include/generated/timestamp_autogenerated.h
 UPD   include/generated/timestamp_autogenerated.h
 CHK   include/generated/version_autogenerated.h
 CHK   include/generated/generic-asm-offsets.h
 CHK   include/generated/asm-offsets.h
 HOSTCC tools/mkenvimage.o
 HOSTCC tools/fit_image.o
 HOSTCC tools/image-host.o
 HOSTCC tools/dumpimage.o
 HOSTCC tools/mkimage.o
 HOSTLD tools/mkenvimage
 HOSTLD tools/dumpimage
 HOSTLD tools/mkimage
 CC   arch/arm/mach-socfpga/wrap_pll_config.o
 CC   common/main.o
 CC   cmd/version.o
 LD   arch/arm/mach-socfpga/built-in.o
 LD   common/built-in.o
 LD   cmd/built-in.o
 CC   lib/smbios.o
 CC   lib/display_options.o
 CC   lib/efi_loader/helloworld.o
 CC   lib/efi_loader/efi_reloc.o
 CC   lib/efi_loader/efi_freestanding.o
 LD   lib/efi_loader/helloworld_efi.so
 OBJCOPY lib/efi_loader/helloworld.efi
 LD   lib/built-in.o
 LD   u-boot
 OBJCOPY u-boot.srec
 OBJCOPY u-boot-nodtb.bin
 SYM   u-boot.sym
 CAT   u-boot-dtb.bin
 COPY  u-boot.bin
 MKIMAGE u-boot.img
 MKIMAGE u-boot-dtb.img
 CC   spl/common/spl/spl.o
 CC   spl/arch/arm/mach-socfpga/wrap_pll_config.o
 CC   spl/arch/arm/mach-socfpga/wrap_iocsr_config.o
 CC   spl/arch/arm/mach-socfpga/wrap_pinmux_config.o
 CC   spl/arch/arm/mach-socfpga/wrap_sdram_config.o
 CC   spl/lib/display_options.o
arch/arm/mach-socfpga/wrap_sdram_config.c:205:25: error: ‘RW_MGR_INIT_RESET_0_CKE_0’ undeclared here (not in a function); did you mean ‘RW_MGR_ACTIVATE_0_AND_1’?
 .init_reset_0_cke_0 = RW_MGR_INIT_RESET_0_CKE_0,
arch/arm/mach-socfpga/wrap_sdram_config.c:206:25: error: ‘RW_MGR_INIT_RESET_1_CKE_0’ undeclared here (not in a function); did you mean ‘RW_MGR_INIT_RESET_0_CKE_0’?
 .init_reset_1_cke_0 = RW_MGR_INIT_RESET_1_CKE_0,
arch/arm/mach-socfpga/wrap_sdram_config.c:219:22: error: ‘RW_MGR_MRS0_DLL_RESET’ undeclared here (not in a function); did you mean ‘RW_MGR_SGLE_READ’?
 .mrs0_dll_reset  = RW_MGR_MRS0_DLL_RESET,
           RW_MGR_SGLE_READ
arch/arm/mach-socfpga/wrap_sdram_config.c:220:26: error: ‘RW_MGR_MRS0_DLL_RESET_MIRR’ undeclared here (not in a function); did you mean ‘RW_MGR_MRS0_DLL_RESET’?
 .mrs0_dll_reset_mirr = RW_MGR_MRS0_DLL_RESET_MIRR,
arch/arm/mach-socfpga/wrap_sdram_config.c:221:17: error: ‘RW_MGR_MRS0_USER’ undeclared here (not in a function); did you mean ‘RW_MGR_MRS0_DLL_RESET’?
 .mrs0_user  = RW_MGR_MRS0_USER,
arch/arm/mach-socfpga/wrap_sdram_config.c:222:22: error: ‘RW_MGR_MRS0_USER_MIRR’ undeclared here (not in a function); did you mean ‘RW_MGR_MRS0_USER’?
 .mrs0_user_mirr  = RW_MGR_MRS0_USER_MIRR,
           RW_MGR_MRS0_USER
arch/arm/mach-socfpga/wrap_sdram_config.c:223:13: error: ‘RW_MGR_MRS1’ undeclared here (not in a function); did you mean ‘RW_MGR_IDLE’?
 .mrs1  = RW_MGR_MRS1,
       RW_MGR_IDLE
arch/arm/mach-socfpga/wrap_sdram_config.c:224:17: error: ‘RW_MGR_MRS1_MIRR’ undeclared here (not in a function); did you mean ‘RW_MGR_MRS0_USER’?
 .mrs1_mirr  = RW_MGR_MRS1_MIRR,
         RW_MGR_MRS0_USER
arch/arm/mach-socfpga/wrap_sdram_config.c:225:13: error: ‘RW_MGR_MRS2’ undeclared here (not in a function); did you mean ‘RW_MGR_MRS1’?
 .mrs2  = RW_MGR_MRS2,
       RW_MGR_MRS1
arch/arm/mach-socfpga/wrap_sdram_config.c:226:17: error: ‘RW_MGR_MRS2_MIRR’ undeclared here (not in a function); did you mean ‘RW_MGR_MRS1_MIRR’?
 .mrs2_mirr  = RW_MGR_MRS2_MIRR,
         RW_MGR_MRS1_MIRR
arch/arm/mach-socfpga/wrap_sdram_config.c:227:13: error: ‘RW_MGR_MRS3’ undeclared here (not in a function); did you mean ‘RW_MGR_MRS2’?
 .mrs3  = RW_MGR_MRS3,
       RW_MGR_MRS2
arch/arm/mach-socfpga/wrap_sdram_config.c:228:17: error: ‘RW_MGR_MRS3_MIRR’ undeclared here (not in a function); did you mean ‘RW_MGR_MRS2_MIRR’?
 .mrs3_mirr  = RW_MGR_MRS3_MIRR,
         RW_MGR_MRS2_MIRR
arch/arm/mach-socfpga/wrap_sdram_config.c:234:15: error: ‘RW_MGR_RETURN’ undeclared here (not in a function); did you mean ‘RW_MGR_MRS3’?
 .rreturn  = RW_MGR_RETURN,
        RW_MGR_MRS3
arch/arm/mach-socfpga/wrap_sdram_config.c:236:13: error: ‘RW_MGR_ZQCL’ undeclared here (not in a function); did you mean ‘RW_MGR_MRS3’?
 .zqcl  = RW_MGR_ZQCL,
       RW_MGR_MRS3
scripts/Makefile.build:278: recipe for target 'spl/arch/arm/mach-socfpga/wrap_sdram_config.o' failed
make[2]: *** [spl/arch/arm/mach-socfpga/wrap_sdram_config.o] Error 1
scripts/Makefile.spl:398: recipe for target 'spl/arch/arm/mach-socfpga' failed
make[1]: *** [spl/arch/arm/mach-socfpga] Error 2
make[1]: *** Waiting for unfinished jobs....
 LD   spl/common/spl/built-in.o
 LD   spl/lib/built-in.o
Makefile:1664: recipe for target 'spl/u-boot-spl' failed
make: *** [spl/u-boot-spl] Error 2
FawazJ_Altera
Kindly make sure to follow the steps here:
https://github.com/altera-opensource/u-boot-socfpga/blob/socfpga_v2019.04/doc/README.socfpga
This will generate the handoff files. Hardware wise it should be supported. Uboot wise, I will check with our internal engineering to confirm if 2019.04 supports LPDDR2
Thank you
tlang15
GBies
So have You figured out whether the lpddr2 is suported?
I'm trying to build spl for project generated in q20.1 with CycV and LPDDR2 but have very simmilar compile time errors.
Should I use q18.1 for this?
Tony_777
@FawazJ_Altera, has Intel stopped supporting LPDDR2?
https://github.com/altera-opensource/u-boot-socfpga/blob/9ad6dad583130e600e835a0d3ff821359b9dc9ab/arch/arm/mach-socfpga/wrap_sdram_config.c#L236
Which Quartus and SoCEDS version should I use to build the bootloaders for the board with LPDDR2?
FawazJ_Altera
One more thing, can you try to create uboot using 18.1? this will use older uboot version.
tlang15
If I build the project using Quartus 19.1 but use EDS 18.1 (and U-boot socfpga_v2013.01.01 ) when creating BSP
and building SPL/U-boot, SPL builds (and boots) just fine.
