573 Discussions
SOCEDS tool issue: quartus_cpf: command not found
CAlex
New Contributor II
Here is my environment:
Win 11 , WSL2 Ubuntu , Quartus Lite 22.2STD, SOCEDS std 20.1, ARM DS 2021.1
When I was compiling the GNU-FPGA example for the cycloneV, the following order cant take:
1. cp -rnL order.
2. quartus_cpf order : quartus_cpf -c soc_system.sof soc_system_nodc.rbf
When I tried to do it on wsl2 the issue comes:
       FPGA-CV-GNU$ quartus_cpf -c soc_system.sof soc_system_nodc.rbf
My Path setting is:
       QUARTUS_ROOTDIR=/mnt/c/intelFPGA_lite/22.1std/quartus
I've tried use the default path settings:
        /mnt/c/intelFPGA/20.1/qprogrammer
But result the same.
So what's the right path settings to solve the problem.
Thank you.
Reguards
CAlex
New Contributor II
YES, I got it , the WSL2(Ubuntu) cant hold the SOCEDS, so you MUST use MSYS2 MSYS in administor mode.
Please do whatever you need to this thread.
EBERLAZARE_I_Intel
Let me have a quick check, BTW have you tested on WSL1? Revert to WSL1 and tested?
For NIOS II EDS the WSL2 is not supported:
https://www.intel.com/content/www/us/en/docs/programmable/683525/21-3/installing-windows-subsystem-for-linux.html
CAlex
New Contributor II
Well I think the main issue would be python, SOC EDS is using PYTHON 2 I guess. And all WSL cant install it, it would say "do you mean python3 for python " or something like that.
I gave up using windows to run the SOC EDS.
Sorry I cant test for you.
Please do whatever you must to this thread.
Reguards
Alex
EBERLAZARE_I_Intel
Ok, got it, thanks a lot for the info we shall channel the feedback to our engineering team.
The SoC EDS is no longer used in our new bootloader build, for reference for our new bootloader build:
https://www.rocketboards.org/foswiki/Documentation/BuildingBootloaderCycloneVAndArria10
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
